0 Members and 192 Guests are viewing this topic.
stivep
Quote from: John.K1 on January 05, 2016, 02:56:11 AM
But you already did. You have working device. Or not? With all the respect Atommix93rdAtom1 ,
your words should have some solid prove for what you claim.
So far it sounds like when Mr Keshe's claims (free energy  device, healing device, flying car etc...)
but with no prove what so ever and in Belgium police is after him for fraught.
You know what I mean. We need to distinguish between the people who
just forget to take morning medication from people who can really contribute
and share some practical knowledge to help to other experimenters.
In case of Putin -I think Russia has lots of their own people building this stuff. Doe's he wants to "poison" his own country?
I don't think so  :) To think it as Putin's attack it looks to me a bit as paranoia .
I guess ALL governments have "Free energy" unit in their safes. And some countries also UFOs.
I can say I have free energy device too.
I have knowledge how to build TPU of SM.
Me and our private group we know the secret .
It is not gonna take long to prove it to you  ;) If this gonna be a wish of our master.
Anyway, I like you some of your pints of view.
My friend the Atommix93rdAtom1guy is lunatic:
QuoteAtommix93rdAtom1-
I will put you on the safe road unless you really want to play with high voltage deadly RF frequencies and attract radiation into your body and home
Is that what you want to do
he is not able to differentiate between radiation that is harmful( the higher the frequency
the higher is energetic level of each  period - high energy photons and particles)
and
electromagnetic wave (EM) radiation  up to ultrafiolet,
the unfortunate is that  word "radiation" is used in both instances, but we deal with two  different animals.
There is no and never will be any EM radiation that you going to have at your  home that will bring you a harm.
Photon  is unit of EM .
Photon does not have mass.
Photon  is energy carrier.Photon is frequency independent.
However The energy of photon depends from frequency.
Photons can not interact between themself, can not multiply, can not add nor subtract.
Photons do not see each other.
Photons do not know  about presence of other photons they are "blind" to other photons.
QuotePhotons have no rest mass, but have momentum and energy..
After the photon collides with an electron, the photons energy and momentum is turned into Kinetic energy,
the photon's wavelength is found to have been changed by one Compton wavelength (2.43 x 10-12 m)
Photons can only interact with mass.
When Photon that is coming from Sun strike particles of air  in ionosphere than it deposits ( photon) energy into this particle creating
Aurora or ionisation of the air.
That is why  we call it ionosphere. This in an example of converting a photons energy/momentum.
Energy of Photon deposited into mass, converts in most of  the cases "directly into heat".( that is why we feel warm  in direct light from the sun)
Because energy of Photon of ultraviolet is high enough to heat skin fast with increased depth of penetration  , we might have skin cancer when exposed  for to long.
At the same time we can be exposed with all of our body to 1KW transmitter  perfectly tuned to  omnidirectional antenna( no waveguide )
at the distance of 20 inches  for 100 times longer    time and we will see say possibly  ~3% of energy  of photons
of ultraviolet deposited on 1 square centimeter of our skin.
There is no rule  here as different skin from different race and pigmental consistence reacts differently
The troll called Atomm is a nonsense.
Another important factor is distance from the EM  wave transmitter ( photon producer/transmitter)
The density of flux lines is inversely proportional to the square of the distance from the transmitter
So mostly when dealing with 5kW at 1GHz just 20  inch away perfectly tuned to  omnidirectional antenna( no waveguide )[/size]is not going to create enough of heat in your body to do any harm to you.
Any other lower frequency than that will have less and lesser  energy per period.
Most if not all of Russian experimenters works on KHz  frequency region.
So the Atommix93rdAtom1 guy is lunatic, Weirdo, retarded or he is just hungry attention low life.
He does not have  any academic level, nor any  level that could be appreciated.
All he can do  is to be practical... experimenter if any.
The good point is that people mentally disturbed can some time do brilliant discoveries  just by accident.
It is like  you winning lotto.
Some time this kind of people can lead you to  some very interesting directions, like iron wire for coil..
I'm intrigued by that.
But  despite all of the above talking to lunatic is mostly waste of time
Wesley
Very Low frequency  EM of say 20Hz or microwave band  or visible light  including ultraviolet is not harmful to your body.
However because energy per one single period ( sinusoidal / transversal ) is higher when  wavelength/ frequency  increases, than at X-ray, Gamma level Energy  per period is so high that it can ionize our body. Our body  is mostly made from  water. and we are  mostly made from vacuum.
the prove of that  is easy to spot when you look  how far is first electron  from nucleus and how small is electron comparing to nucleus or even to  proton or neutron.
We are  all mostly made out of empty space.
Dog-One
No worries Wesley, Mr. Atommix won't show us a fraction of what you have showed us.
The good news is Mr. Atommix arriving on the scene, which tells us we are somewhere nearing the target area.  As we get closer, Mr. Atommix will be whisked away and replaced with the big guns.  At that point the genie is out of the bottle.
It would be welcome if we could attract a true whistle blower that has seen the inside of some very secret laboratories, knows exactly how these devices work and is willing to break his or her secrecy oath.  Knowing the foundational concepts and a few practical development tips would be priceless and advance our progress exponentially.  I'm guessing those people don't frequent overunity.com or they are too scared to receive their punishment.  It's truly a shame, because what they don't seem to know is they will be punished anyway and by staying silent, they will never be able to help anyone else.
AlienGrey
The original Tesla STATIC CHARGING phenomena reproduced here watch it all the way through.
http://www.electroboom.com/?p=575
AlienGrey
Quote from: shadow119g on January 05, 2016, 10:18:59 AM
Hi
I have been trying to replicate the Kapanadze device but my microwave
transformer keeps over heating?
Do you have a solution?
Thanks
Shadow
Ha Ha You must have seen welder and instant soldering iron guns ? Any way if you short out transformer with shorted turns what do you expect, it burns out !
you need to limit the current through the high current winding, so add a resister or filament lamp, string some cheep old fire element type restrictive value in series then play again !
AlienGrey
 Offline Atommix93rdAtom1
professor pop-kiss (supper car fame) ? or what ever your name and credibility entails  is, please note that the ground Rodney brigade is not Russian at all it's a lie ! it was invented by Henry moray an American ! you say your an inventor who has given or sold your self ideas to the American government, now would that be the elected government or the secret one, Steven Greer refers to ?
We need an energy that's linked to zero point energy sucking from that dumped into the immediate environment or what ever you want to refer to it as, and not gas or oil based in any way you mentioned 360 hz but their are other resonant frequency's that are in tune with the universe, why not cut the crap and show us a device we can use, with out the spelling mistakes and colorful piss taking metaphors, And don't lecture us on the Grid, it's power lines run all over the country radiating radon gas from the pylons and the leakage will light mercury vapor tubes if planted in a field directly under the feed lines and then their are cell phones and the micro wave radiation that goes with that, disrupting bugs like bees ect we are all beings of frequency, you might think we are stupid but we can see through you, daddy oh!
https://www.youtube.com/watch?v=K0C7sj6cskE
have a nice day ;)
Many thanks
for the loan of you sight ! re 360hz
