0 Members and 207 Guests are viewing this topic.
cheappower2012
Amazing how people  get worked up when someone says a device could be faked.
I believe Westley saw a real device in Georgia,I don't buy hes conclusions as to how it worked at all.
One problem that I see is people do not understand the level of deception Kapanadze
operates under.He can fool very smart people easily,just because you have university training doesn't mean
you will figure Kapanadze's device out or not be fooled.Kapanadze's primitive workshop points to one of two conclusions
its a fake or its very simple but strange.Kapanadze lies and lies,he will never give up the secret of hes device
and will take it to hes grave.Theres always the possibility that something could be faked
this is why part of investigating hes device is, if it was faked ,how,if it is very hard to fake then theres a good chance its real.
PolaczekCebulaczek
Kapanadze never make any presentation in the forest far away from power sources, why? Sure, Wesley witness the device but only in Tariel's garage ... it just looks like Kapanadze is transmitting current trough ground from hidden transmitter or Kapanadze free energy device is stealing electricity from utility company trough earth (utility poles are grounded) or home electrical grounding system.When you connect audio amplifier to earth near your home you will hear 60/50 hz buzzing noise, just a thought...
cheappower2012
There are only 3 ways to fake things one is thru a hidden wire,
a ground forms one connection plus a hot forms the other.
An inverter in a box with a battery,a wireless transmitter/receiver.
The amount of energy the device(2005 green box as an example) consumes
close to 5kw,a battery/inverter would not work,
a wireless set up would not work,a hidden hot wire
would not work.Kapanadze's goal is not to demo a device in an area
that would indicate it must be real,but to
show a person it could be real,and use hes greed against him,in order to get money from him.
He has no plans of ever revealing what hes secret is.People need to understand
how Kapanadze thinks,I don't think he understands the concept of truth.Each possible method of trickery should be presented  for various devices,along with counter views for the devices working.
Hoppy
Quote from: cheappower2012 on January 25, 2016, 07:25:56 PM
We have been over this umpteen times to exchange ideas and counter views! I say again, that a hidden hot wire would work, or to more exact a hidden cable with the bearded man's assistance to get the power routed into the device. I have also suggested that the Aqua2 was fed by a hidden wire through the earth braid. Yes, Kapanadze is clever but not clever enough to fool everyone. Furthermore, the lamps in the 'green box' video were consuming nowhere near 5Kw.
cheappower2012
Hoppy first off wattsup suggested an explanation for a possible way to fake the green box video,
wattsup was in the tpu group with me for years,if he can't figure out something,
he calls it a fake and suggests a way that its faked to rid himself of it,
he did this one time before with another device.They remove the ground wire from the faucet
and connect it to the lights directly,
they measure the current then thru the big black cable.In this green box video  it has an English translation
they wanted to find out if the device will light one bulb,they read 5 and 4 amps,then two bulbs
8 amps,so all 5,5 times 4=20 amps,20 times 220v=4,400 watts.In addition aking21 stated that hes contacts
conform the existence of 1,000 watt bulbs used in Georgia,crazy but true.This video has only the current readings of the light bulbs.
https://www.youtube.com/watch?v=NBLrRIUiN6w&feature=youtu.be
If you look at the green box video,you will not see a  direct ground connection other than the thick
black cable going to the faucet,you need both a solid ground and a hot side.
On the aquarium 2 video althu your theory is possible,you can not show a connection to the coil other than the ground side
because there is none,you need two sides to transfer current only one side is shown.
The great problem with the aquarium 2 is they never took a reading at the plug,this would then set
a limit as to possibilities,is it ac or dc,if ac or dc what voltage,if ac what frequency.
You could infer Tariel is like David Copperfield and must have faked it.
