0 Members and 123 Guests are viewing this topic.
stivep
Quote from: TinselKoala on February 08, 2016, 11:25:08 PM
Wesley... aren't you worried that your instruments may get all "nano-coated" inside from being connected to the Keshe device? I think this will probably void your warranties and make your calibrations questionable ....     ;)
(Also... could you please resize your images so that they are no more than 1024 pixels wide. If you need to show a closeup in greater magnification, you can crop out the area of interest and blow it up, but the images wider than 1024 pixels cause problems for people with narrow screens.... )
I did removed the last pictures.
The others I have  no access to.
Sorry for the trouble
As far as nano coating I take it as  a joke :)
I had no problems before.
I was taking pictures   with  Nikon D600
I recently switched to   FDR XA-100 Sony.
But in both instances I was taking snap shoot  using  FullShot9.5 this is just excellent program.
So I assume  there should be no difference  what camera I'm using.
I need to  check  properties  of FullShot9.5
But id you  good in it than I take your advice.
Wesley
Quote from: stivep on February 08, 2016, 11:34:34 PM
Wesley
Why do you think I'm the one who is joking? If Keshe's devices work as he claims, then anything connected to them should become nano-coated in its power and sense wiring, no? I'd hate to see you ruining your good equipment by making all the wiring inside them superconducting.
And since you are already seeing readings that indicate more power output from Keshe's device than input..... aren't you worried about this? Have you already decided that your instruments are somehow in error and the device doesn't actually work? Maybe it does work after all and that's why you are getting the readings you are getting.
:P
(As far as the photo size goes.... there will be settings in the camera and in your processing application; both will determine the final size of the saved image. Perhaps you had the Nikon set to make smaller images in the first place. In your application, look for "scale image" or some such setting where you can set the resulting image size in pixels. Normally, 800 pixels wide is enough for the forum. The maximum for this forum to display the page properly is 1024 pixels wide. If you need to show some details up close, you can crop them out of your original larger image and show them in a 1024 pixel wide image. And obviously, the file size in bytes is related to the pixel (width x height), so smaller images will upload/download faster and require less storage on Stefan's servers.
My Canon Xti camera's normal image pixel size is 3888 x 2592 pixels  and I think your cameras will be similar; this is far too large for good display on the forum ... )
Void
Quote from: TinselKoala on February 09, 2016, 04:40:45 AM
Hi TK. I took Wesley's comment to mean that he doesn't take Keshe's claims about 'nano-coating' seriously.
T-1000
Hi all,
Simple question:
Why people are still wasting time on Keshe empty claims and money on that phishing marathon?
Aren't there other free energy prospects to explore?
stivep
Quote from: T-1000 on February 09, 2016, 11:55:16 AM
Hi all,
Simple question:
I like your comment Arunas.
I was asked to  make evaluation of that device and that is only what
I do.
Wesley
