0 Members and 185 Guests are viewing this topic.
What_The_Flux
Quote from: callanan on June 14, 2010, 08:55:00 PM
This could precisely be the assumption that has caused so many not to have come across OU from the ground for the last century. What if indeed there is a minimum threshhold level of power at a certain voltage required for the ground to give up it's OU effect. Sure, very precise tuned circuits at high voltage may be able to also achieve this threshold level but in reality, that maybe like finding a needle in a hay stack which is perhaps why very few people have claimed to have done so.
An initial brute force and untuned or perhaps roughly tuned method is perhaps what is going to allow the OU ground threshold to be reached and replicated by more people then a low power precisely tuned method. Then, when the consensous of success determines that it is all very real, the engineering to reduce the threshold power levels will occur as a natural progression.
I am not encouraging anyone to risk their safety, especially if they do not feel they have the experience to work with higher voltage and power levels in a safe manner, but I am just pointing out that it maybe be a requirement to do so for a greater chance of success and don't want to see more experienced people who are capable of working with such power levels safely, discouraged from trying.
Respectful disagreement with callanan...
All those who have demonstrated this type of device (Tesla, Karpanadze, Smith) all emphatically state that tuning to proper resonance is the most important part of replication. None of these guys implied that brute force was the way to go, more often they implied this was not the case.
@bolt
Kudos to you for your previous comments in this forum re: cracking a walnut with a sledge hammer.
Karpanadze did not work with megavolts... He had a smooth arc which apparently didn't consume lots of power but was enough to trigger a resonance in the primary and secondary of the transformer.
I have just spent three full days reading all 150 pages of this thread (including referenced videos and documents), and so far I have not seen anyone do the math to calculate the L, C and f to create a high Q resonance in the transformer, as Tesla, Kapanadze, and Smith all say are critical. (And believe me, my eyes are so tired right now)
I have seen bolt try to steer people in this direction and get flamed for it. I hope some of you go back and re-look at his comments, because I feel he has looked at and understood the creations of the inventors. I feel that he, as I, appreciate all the creative work so far, but feel that sometimes the experiment stray from the invention for the thrill of seeing the glow of a piece of tungsten.
Anyway, this will be the basis of my experiments in the coming weeks: creating a resonance which minimizes power consumption of source, trying to create harmonic resonance between L1, L2, and L3, and seeking earth resonances between separated grounds (if there is such a thing).
Respectfully,
WTF
xenomorphlabs
@What_The_Flux: Respect, that you took the time to read this whole thread.
Good luck for your efforts to experiment with resonance, don´t hesitate to post your findings.
People have more gotten into experimenting in the Donald Smith thread here, but there is always confusion as to what resonance frequencies Don Smith is actually tuning too in his table top system. The known math does either not apply, is incomplete or his devices simply don´t work, as only once one was running publically for 5 minutes. But you can see for yourself in the Smith thread.
bolt
Quote from: vrand on June 14, 2010, 08:54:26 PM
That Kapanadze photo of his ground wire is perfect, as there is lots of surface area in the thin stranded wires for the "skin effect" of HF current to easily flow through the cable.   :)
Are you pulling my bells? :)
I just said coax is handy for thick cabling for current only no magic skin effect!
bolt
Quote from: What_The_Flux on June 14, 2010, 10:15:41 PM
@bolt
Respectfully,
WTF
Well thank you at least you see something of value in my writings. Not everyone does I am sure but then this forum is not a lonely hearts club so cant please everyone.
Not sure about reading 150 pages though i been away for months and starting at page 145 gets you RIGHT up to speed:)
Groundloop
@aether22,
The HV oscillator came from a USB plasma ball:
http://www.thinkgeek.com/geektoys/science/964e/
I moved two green capacitors from the top of the pcb
to the bottom to make room for a heat sink on the TO-225AA
size transistor. I then added a heat sink.
The plastic tubing is 50mm outer diameter. It has 77 turn with
PVC insulated multistrand wire. The wire is approx. 2mm outer diameter.
Then I insulated the coil with 7 layer of yellow transformer tape. Each
layer can take approx. 1000 Volt. My two turn coil is 2mm enameled
copper wire. The two turn coil is approx. 15mm outside the first coil.
I did use some cardboard and tape to get the coil insulated from the first coil.
My spark gap is two 3mm bolts mounted onto two aluminum L shapes.
I can adjust the distance between the two bolts. The L shapes are mounted
onto two nylon distances 50mm long above the aluminum bottom plate.
Groundloop.
