0 Members and 121 Guests are viewing this topic.
Zeitmaschine
Quote from: leo48 on February 17, 2016, 12:14:03 PM
I tried to mix two different frequencies square wave
Try to mix a) sine waves and b) at least one frequency should be high voltage.
One part of the Stepanov setup is undoubtedly a 3-phase parallel LC circuit. There is no other choice according to the video images to connect it in a different way. A parallel LC circuit which connects to ground is also the main part of a Crystal Radio.
So the choke (one half of a transformer) in that Stepanov setup leaves us with one remaining connector, the virtual ground. Meaning the second transformer (in the background) should be connected to that virtual ground (it correlates to the antenna input of a crystal radio) and it should do something with it.
Since this is quite clear, the only remaining thing to crack is the connection method of that second 3-phase transformer, which is almost for sure connected to a (here hidden) frequency doubler circuit, as we know from the cardboard box setup.
Actually it boils down to have a crystal radio like LC circuit and then to do something extraordinary with its antenna, like exciting the antenna with the help of high voltage instead of some faint radio waves.
Kapanadze Demonstration 28th April 2004 - Shut Off Delay (23-59-19).mp4
The electrons in a crystal radio's antenna are influenced a) by the tuned resonance frequency of the LC circuit and b) by the incoming radio waves.
Question: If we tune a crystal radio to a local radio station, do we tune its LC circuit to the exact frequency of that station or do we tune it rather to twice or half of that frequency for best results? Just asking ... can't find anything about that in the literature (and there is no suitable AM station near for testing).
leo48
QuoteTry to mix a) sine waves and b) at least one frequency should be high voltage.
Right now I'm realizing the equipment necessary to generate and amplify the sinusoidal signals.
but I think it will still take some time.
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
cheappower2012
Zeitmaschine
If you are referring to the green box video where
they measure the ground current of the thick black cable,
there is no ground current .It is an illusion
created by the cheap clampmeter used.Pulses created by the coil discharging
gets mixed in with the ac ,this also causes a digital meter to not get a voltage reading
thats in the video,I also got that effect, the pulses also create a strange effect on the cheap clampmeter
to cause it to read a nonexistent ac ground current.I did an experiment that
showed a false current
by using a clampmeter made by harbor freight that is a clone for the clampmeter used
that showed a false current,
when another clampmeter was used it showed zero amps.
Tariel uses this to create the illusion theres a ground current
to fake out people that hero worship Tesla.Do you have con men in your country
I believe your German,Tariel is a conmans,conman.He is beyond any conman
in hes very ingenious use of resources to fool people,a master of deception
second only to Satan.The setup is a Tesla interface,a 60hz isolation transformer
applies 110 vac 60 hz,to a system consisting of a spark gap(spark plug),a high voltage supply
coil setup as in green box video,an external ground goes to a pipe ground outside.
The ground current is measured at the ground connection, a 60 watt load is used.
With the unit on, light lite, the meter shows 24 amps,with the same conditions my other meter shows zero
current,the correct reading.My conclusion is this meter has some condition
(circuitry problem) that causes a false current reading under the right conditions,
it is made by the same company that makes the cheap clampmeter Tariel uses.Tariel is a tinker
he most likely discovered this particular problem with this meter and used it to fake
people out to create the illusion its a Tesla invention.
In the aquarium 2 device there is a circuit very,very difficult to figure out,it shows
just how smart Tariel is,this electrical circuit can be used to reverse engineer
the aquarium 2 device.However I'm not going to get into this as I'm doing more research
in this area.If you notice that the coils used are air core, in all of Tariels devices,I believe that
theres a new method of generating current involved in the Kapanadze device that does not rely
on an induction mechanism.The coils are a functional part of the device it is not eye candy.
The length of the coil plays a big part not how its wound,phase of the ac plays no part,it is not a Tesla invention.
Zeitmaschine
Quote from: cheappower2012 on February 17, 2016, 05:19:08 PM
Zeitmaschine
First you forgot that this »illusion« shows the correct amps, which are 5000 W (the lamps) divided by 220 V equals 22.7 A (mathematically) and this is approx. what Kapanadze's clamp meter shows. How can a malfunctioning clamp meter measure the correct value?
Second you forgot that Stepanov's clamp meter also shows a clear and steady amp reading. Hence we have now two different clamp meters showing a current that is not real? Kapanadze uses a MASTECH 266C and Stepanov a MASTECH MS2138R.
Then why does my cheap clamp meter, a MASTECH MS2102, not also give me a false reading when I measure my (not existing) ground current?
Should I buy a even cheaper one in order to create the Kapanadze like deception? ???
cheappower2012
Zeitmaschine
Well the problem is if they were really measuring
a ground current then this device(green box) is a fraud.
All thats needed then is a hot side to complete a fraud
you forgot in my setup I used a 60 watt bulb, less than an amp draw
yet it showed 24 amps.Given other factors in the green box
it would show close to the required current draw,the point is the clampmeter
under the influence of pulses shows a false current,my setup does and  hes would to.
In a later part of the video he removes the ground wire from the faucet
and measures one light 4 amps,2 lights 8 amp,so we can assume 5 lights 20 amps.
There is no ground current of any kind,if there was then its fake
a hidden wire trick.Not knowing Stepanov's setup I can't comment
if your sure that a real current reading is taken you should be able
to connect a load to that point.The mixing of huge pulses with the 50 HZ ac,
is what creates this false current effect.If a device  doesn't mix huge
pulses with ac then theres no problem in measurement.There are very few
video's of Stepanov's device,there are many video's of Tariel's devices.
Things are easy to fake,you mean to tell me you don't have any con men in your country. :o
