0 Members and 43 Guests are viewing this topic.
stivep
Few tips for  my friends who post their videos on youtube or document their experiments.
I also need your advise in questions I have posted below.
--------------------------------------------------------------------------------------------------------------------------------In the meantime:
I was trying to make better  video quality  and more advanced  equipment  for my YouTube videos.
I got first D600 from Nikon  I was impressed with it   and all I found out is as long as you play with toys you are OK....... not good  but OK.
Than you play with other more than 460 instruments in the lab and you not good in anything.
You  do not have time to even touch all of the buttons.
So any time I have touched D600 I was recalling my learning curve from the first time.
Apart from that it does not really is something that  I like ( just the average  general public toy  made for the crowd to play with.)
Than I thought than in my travels I need to document more details  for later analysis .
I do not want to be again in the situation that Tariel Kapanadze or Ruslan or Akula or any other guy will just show me  his FE in the dark room 5 minutes before my flight back to USA.
So conclusion was Nikon D810 but I need to learn  again and find that for quick shots  36.3 MP  quality  is not  what I need .
I decided to stay for while with  D600 that is not made for rapid deployment when time to prepare is close to none.
Honestly it sucs.
-mike is catching internal motor squicks
-light adjustment is not intuitive and you can not blindly press  and shot without  checking first.
-light changes say on of ligt-bulb on FE device  makes camera to give you completely not what you set it for.
-Slow focus and zoom.
- At the end  20 hours of trip, money spend,  and all you have got  as your evidence is your  video material.
So I decided to try FDR  AX-100:
- with 4K quality,at 30fps
-or at HD  120 fps, (60fps)
Before I spend money I  look at at something  often 6 months or more and than buy it used.
So I have got it for 800.. not bad  at all.
Sony web offers free  soft  upgrade and  editing program   however I like Sony-Vegas better.
However Sony Vegas Pro does not give me ability to  make precise marks, pointers, comments and so on.
So I got: BB FlashBack Pro 5 made mostly for editing of academic or educational video materials. I like it very much .
It is  consuming a lot of the Hard Drive  and for longer videos it is good tha have separate computer.It crashes a lot
however  it allows you to work wit not much of a problem if you safe your work every  few minutes.(Empty memory buffer)
Than another problem arrived incompatibility of the formats between Sony Vegas Pro and BB FlashBack Pro 5.
Any time I want to use files from one program  to work with  another I  need to convert it and by that I lose time and often quality of the material.
In the small places lenses of D600 and FDR AX-100 are to narrow so  the device model:
0.75 Wide Converter For HD Model HD75X-EXII[/font]
0.8   Wide Converter For HD Model HD75X-EXII
With suitable adapter rings makes trics done.
Other types offered by Sony or any other competition sucs.
However Lens  weights is more than camera alone.
IF you shop around you may end up with $100 for  it plus $70 for all adapters needed.
For who it may concern links are:
http://www.dvinfo.net/forum/sony-pxw-x70-fdr-ax100/527367-wide-angle-lenses-sony-fdr-ax100.html
http://www.dvinfo.net/forum/sony-pxw-x70-fdr-ax100/526964-x70-live-shots.html
Now Questions;
1. please give me links  to professional  quality programs  for animation. ( so let's say I can present  parts of mechanism that  are
nicely separated and assembled in this animation)
2. Is anyone who is more  educated in Sony Vegas Pro?
3. How can I easily go around compatibility issue  between  BB FlashBack Pro 5 and Sony Vegas Pro in regards to format?
4 . Any one knows better program  for educational material editing than BB FlashBack Pro 5 ?
Wesley
Zeitmaschine
Quote from: cheappower2012 on February 17, 2016, 10:44:51 PM
Zeitmaschine
Well the problem is if they were really measuring
a ground current then this device(green box) is a fraud.
Simple question: Why does a crystal radio need a connection to ground? Is it because there is a small ground current flowing and without that current the crystal radio cannot work?
If so, then what physical parameter is causing the limit? Why should a small ground current be possible, but a larger one not?
Thanks in advance for answering that question, so we can find that parameter.
SoManyWires
Quote from: stivep on February 18, 2016, 01:58:55 AM
Honestly it sucs.
Now Questions;
Wesley
hi, cameras are not my strength in knowledge, or most things for that matter. lol
though you had me thinking of something that might be useful for evaluations. point cloud.
maybe you have considered that one already and dont really have any use for it.
if a 3d scanner was affordable and useful to getting close to replication (roughly .5mm four around 1000 dollars or less used, or lower res at .8mm for about 250 USD)of the machinery you might happen to be normally just taking moving 2d pictures of using standard video. they might want a quad processor with 8 gigs of ram or higher to process the math into 3d rotatable and zoomable scans. zoomable to the point of placing view from inside a point cloud itself.
i agree that 2d is helpful too though, am just mentioning ideas if helps.
there is also something called 3d cameras. they operate similar to how a 3d scanner works, and are able to capture depth to field view.
its possible to actually take a picture with one of those 3d cameras, then draw a line on the edge of a object in the picture, then and get a close measurement of things like furniture. its not always accurate though, and some proper lighting and shadow angles might need adjustment.
there are new products for 3d scanning just on the market horizon from what i understand of it, and it should become more affordable.
also wanted to say your lab resembles an engineering level on a star class interstellar ship. impressive!
Hoppy
Quote from: Zeitmaschine on February 17, 2016, 07:40:43 PM
First you forgot that this »illusion« shows the correct amps, which are 5000 W (the lamps) divided by 220 V equals 22.7 A (mathematically) and this is approx. what Kapanadze's clamp meter shows. How can a malfunctioning clamp meter measure the correct value?
Zeit,
The lamps are running nowhere near 5000W in the video.
