0 Members and 83 Guests are viewing this topic.
Hoppy
Quote from: cheappower2012 on February 17, 2016, 10:44:51 PM
Zeitmaschine
Well the problem is if they were really measuring
a ground current then this device(green box) is a fraud.
All thats needed then is a hot side to complete a fraud
you forgot in my setup I used a 60 watt bulb, less than an amp draw
yet it showed 24 amps.Given other factors in the green box
it would show close to the required current draw,the point is the clampmeter
under the influence of pulses shows a false current,my setup does and  hes would to.
In a later part of the video he removes the ground wire from the faucet
and measures one light 4 amps,2 lights 8 amp,so we can assume 5 lights 20 amps.
There is no ground current of any kind,if there was then its fake
a hidden wire trick.Not knowing Stepanov's setup I can't comment
if your sure that a real current reading is taken you should be able
to connect a load to that point.The mixing of huge pulses with the 50 HZ ac,
is what creates this false current effect.If a device  doesn't mix huge
pulses with ac then theres no problem in measurement.There are very few
video's of Stepanov's device,there are many video's of Tariel's devices.
Things are easy to fake,you mean to tell me you don't have any con men in your country. :o
I agree with your reasoning here. The green box video device would have been fairly easy to fake using a hidden 50Hz current supply. The earth wire was not entirely necessary, as the ac current was most likely taken into the device via the cable being held in the bearded man's hand.
cheappower2012
   Zeitmaschine
https://en.wikipedia.org/wiki/Monopole_antenna
You can not have a one
connection path to ground and get a high current thats not possible.You need two
connections.It is not possible to get a huge current from only a ground connection only unless
you either have a very high frequency generated from one point to ground or a high voltage.
There are one wire ac 50hz transmission systems,the voltage at the transmitting portion is step up to a
very high voltage so it can pass thru the dirt with as little loss as possible
the dirt acts as the other wire it has resistance causing loss,at the receiving end the voltage is stepped down.
Having an ac 50 Hz
high current thru a wire going to ground where there is only one wire is impossible unless its fake,a hidden hot wire is being used.
Zeitmaschine
Quote from: Hoppy on February 18, 2016, 05:09:56 AM
Zeit,
The lamps are running nowhere near 5000W in the video.
In which video? Green box in full bright sunlight? Or this video? Looks to me like 5000 Watts of light easily.
Quote from: Hoppy on February 18, 2016, 05:35:41 AM
And that's the reason I think why no one seems to be really interested in the Stepanov device. Because it is all presented in plain view (at least for the bystanders and the television crew) so no one can argue there is something hidden (like a wire) in order to conduct a scam. That's unfortunate for all who want to put all those videos in the fake corner.
Anyway my question still stands: Does a crystal radio need a ground current to work, and which parameter is the limiter of that current?
Quote from: cheappower2012 on February 18, 2016, 07:10:03 AM
Yes, we have high voltage. I'm constantly writing about that, namely connecting high voltage to a receiver antenna.
If we assume that the following equation is correct
- the magnitude of a crystal radio's ground current equals the free energy received by that crystal radio
then what happens if the radio transmitter is only a few meters away? Do we get a larger ground current and hence more free energy?
What if the radio transmitter is connected directly to the antenna of the crystal radio? Could it then happen that the ground current (which represents free energy) exceeds a level, so the receiver produces more energy than the transmitter consumes?
Hoppy
Quote from: Zeitmaschine on February 18, 2016, 07:20:25 AM
In neither.
Zeitmaschine
Says who?
And if it is only 2000 Watts then this free energy is not good enough?
