0 Members and 87 Guests are viewing this topic.
Hoppy
Quote from: Zeitmaschine on February 18, 2016, 07:55:11 AM
Says who?
And if it is only 2000 Watts then this free energy is not good enough?
Me.
Yes of course, if its free.
wattsup
Not again........we covered the Green Boxy already somewhere between page 1 and page 1484 of this very short thread. hahaha
Summary is simple. Ground wire from faucet goes to the bearded guy (BD) who holds a few loops of the ground wire in his hand where they introduce an actual hot line into the ground wire going from the BD to the center of the TK Coil (TKC). Notice they only look at amperage between the BD and TKC. That's because you cannot take clamp on measurements on a neutral or ground line. You always need the hot side.
When the ground wire enters the center end of the TKC, that's where they opened it up and sent the hot to the hot side of their output and let the ground wire pass through the TKC to exit from the other side to create the illusion that the ground wire only passes through the TKC. Why else would you even bother passing it through the TKC if it is only a ground that could be connected from the outside to the output.
The BD never moved one iota from his initial position. For humans to be so "on guard" must be more then to simply hold a few turns of ground wire in his hand. The hot connecting is on the ground and his shoe is making the connection that goes up his pants, his shirt then down his sleeve to then meld into the ground wire turns in his hand and bingo, you now have a very convincing show à la David Copperfield.
We all know that coupling 5000 watts through the TKC of the Green Box or even the Aquarium units is simply impossible to conceive. If there is anything relative to a primary and secondary, those wires would generate a good 95% coupling loss so how could they have coupled so much juice.
The spark gap they show is not even using 1 amp. If it was 1 amp it would be as thick as the metal points used and not this very thin spark which is just peanuts to the effect they are showing in the lit bulbs. Does not make sense.
The final nail in the coffin is time itself and human nature. After all this time, none of TKs cohorts who knew the deal ever came forward to claim the glory their master would not. That's is not possible if this was true given their level of need for any source of revenue, someone would have come forward by now. But if the device is fake, they all know already that coming forward is not an option and their only card to play is fake demos for hire.
TK, like SM was a fake and anyone playing the same game of SHOW but don't TELL is also a fake.
wattsup
PS: As for those who may say "wattsup always says it's fake when he can't figure out how it works" should think again. What's harder finding a Wire X or how they faked something or trying to rationalize how they made it work when it is in fact a fake. The former has a time limit while the later does not. You can spend your next 10 more years trying to develop a TK device and never do it even if you worked through 50 variables one by one. In the end you will arrive at my same conclusion which is not a cop out. It's just the reality we have to deal with every damn day of this OU life we decided to lead. In the end, the only real position on all of these purported devices is very simple. If you do not disclose complete function, YOU'RE A FAKE or you are not HUMAN, since you turned your back on helping man while you concentrate on playing these petty "I know - you don't" games while the world is in such dire straights. You need to draw the line somewhere otherwise you will be chasing an endless shadow. In the end, you are much better off working on your own devices then trying to follow any OU simulations.
Zeitmaschine
Quote from: Hoppy on February 18, 2016, 08:07:27 AM
Me.
Magic eyes?
Then why does the clamp meter show 25 amps measured directly at the lamps, not the ground wire?
25 A times 220 V equals 5500 W
Quote from: wattsup on February 18, 2016, 08:18:32 AM
On the contrary! Again and again!
So as it seems some people going slowly into panic mode because part of the Kapanadze/Stepanov device has been already cracked. 8)
Hoppy
Quote from: Zeitmaschine on February 18, 2016, 08:30:30 AM
You crack me up! The laughter continues.
Zeitmaschine
If so or not: Then who told the man with the clamp meter to take the measurements exactly that way? Is he also in on the secret?
Fakeability does not contradict reality.
So what do we have so far? We have a parallel LC circuit, one side connected to ground like a crystal radio (single- or three-phase) and we have a frequency doubler circuit. That's for sure. Now what could be the missing third part?
What we not have: A spark gap and a big self-made coil on an old kitchen roll holder. That's mere nonsense.
Electric energy always flows from higher frequency to lower frequency. A solar inverter makes use of this when it sends solar electricity into the power grid (making the meter running backwards).
Therefore I would guess, the LC circuit should resonate at 50Hz, whereas the antenna should oscillate at 100Hz in order to transfer the free energy captured by the antenna and/or ground into the 50Hz grid.
Maybe I'm wrong, hence some experimenting is needed (whilst the laughter continues).
