Zeitmaschine
cosmoLV: » ... if you once get this magnetic field - you will be amazed and I'm sure that you will not post schematics!«
The major problem with this thread (and also others) is that almost no one looks back and reads what is written 10 or more pages ago, because he thinks, if the latest page does not provide complete information how to construct a free energy device, then the previous pages will have even less information on it. Therefore the thread goes continuously in circles.
Here back in 2011 Guntis explains the basic principle in one sentence.
The theory: A transformer has to have at least two primary coils and one secondary coil. The first primary coil generates high voltage pulses in the secondary coil, whereas the second primary coil generates an additional magnetic field. One primary coil works at twice the frequency of the other. Therefore neither a flyback from a TV nor a transformer from a microwave oven is suitable for that.
Now I'm anxious when the time of amazement will come to me.
Hoppy
Quote from: Zeitmaschine on February 23, 2016, 10:25:23 AM
I predict that the circles will not end until the thread is eventually locked. Why do I say this - simply because its not possible to change hardened beliefs using videos and forum posts as a medium. Nonetheless, its still worth going round in circles, if only to gain additional snippets of information to fill gaps in our knowledge and have a chuckle along the way.
When do you predict the next circle will start.  ;D
Zeitmaschine
It is like a washing machine which turns also around in circles until the washing is clean. Here it is the brain that gets washed from false believes like »there is no ambient energy« or »its impossible to use that ambient energy even if it is there«. After each washing cycle the brain sees much clearer.
All the Kapanadze and Stepanov devices do not have a visible antenna. So do we need one or is that one more component that can be dropped safely?
leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
Zeitmaschine
That line is connected outside to the load and inside to the hidden LC circuit via the center core of the coax cable.
I'm still pondering why that stuff should actually work. Let's reconsider: One transformer coil generates high voltage (a static electric field, ionization), then a second magnetic field converts that static electric field into a magnetic field. This magnetic field can do work.
So what's the point? Any magnetic field can do work. We can switch on and off a magnetic field generated by electric current, but we need energy to create it. A permanent magnet needs no energy to generate a magnetic field, unfortunately we cannot switch it on and off, so we need energy to move that magnet in order to generate electric current.
But if we switch on and off a static electric field (50 or 100 times a second) which is then transformed into a magnetic field, then we have a strong switchable magnetic field almost for free (two magnetic fields generated by the two primary coils plus the magnetic field of the transformed static), because a high voltage transformer with an open secondary does only consume a low idle current. The surplus energy then is coming out of the static electric field itself.
The magnitude of the transformed magnetic field should depend on the level of the high voltage. That level of high voltage depends on the numbers of windings of the high voltage coil, but the numbers of windings do not matter, because the secondary high voltage coil is not closed (no current), so the primary coil can't »see« that secondary coil (no Lenz's law).
Not sure if I got it.
