0 Members and 116 Guests are viewing this topic.
Zeitmaschine
Does a static electric field interact with a magnetic field?
Harry McLaughlin:
»Sure.
They interact, or better said, they combine to produce a flow of energy.«
Guntis:
»Static magnetics field or ionisation - called also as Dead Magnetic Field, but we can convert this field to meka a work«
Quote from: Hoppy on February 23, 2016, 03:49:18 AM
I agree that the blue coils do nothing apart from carrying current to the load.
I'm not even sure about that. Why routing the current through the blue coil? It is an unnecessary resistor. Routing the current straight through the plastic tube would also do the job.
I agree that the transformer is not capable of supplying the necessary current to the load, so it and its fancy coil are also eye candy because it could not possibly induce sufficient current into the blue coils, which we also agree do nothing.
Hence a new diagram to make it more clear. The phrase »it« translates to: Could it be possible that this green 3-phase transformer can generate a work and a flow of energy? If nothing else generates that flow of energy, then yes.
Hoppy
Quote from: Zeitmaschine on February 26, 2016, 02:20:40 PM
The power source is carried through the braid IMO. Therefore the current does not need to pass through the whole of the blue coil, as it can be patched in at any hidden point. The blue wire is not co-ax.
cheappower2012
Zeitmaschine
The connections on  green transformer pin 2 and pin 2 are connected to ground look at
picture of connection of blue wire and braid.The small coil winding is
part of the fancy coil.The fancy coil is a Tesla invention a kind of butterfly
coil,used for a high frequency application I believe,Kapanadze threw that in to fake people out,to enforce its a Tesla invention.
Where your question marks on your picture are just draw a coil,the blue coil
is constructed to fake you out it is simply a coil,one end goes to the plug of the heater
the other end to pin 1.The coax cable center connector must connect at some point to the blue
wire going to pin 1 of the green transformer.the theory that the coax could carry the current
to light the heater is possible.Here are a few facts we don't know,no readings were done at the
plug end of the heater is it ac,dc,what voltage ,if ac what frequency,all this is unknown.
No connection of the coax center connector to the blue wire can be shown,its assumed to be connected.
No video was recorded
showing the aquarium 2 device operating with the ground wire disconnected.Aking21 told me
that the device was disconnected for a time and it still worked,the ground was disconnected
at the connection outside.Is aking21 lying or telling the truth.Unfortunately there is no absolute conclusion some
will believe its simply a trick, others may believe its real.Take the case of the
green box device,to disprove wattsup theory which I believe is silly,the bearded man
with the cable shoved in hes clothing,steps on a  cable carrying over 20 amps at 220 vac
this generates a loud noise and a giant spark it also fuses wires together it would draw attention.
However to disprove this it requires a picture of  someone connecting the black cable to either the
top of the coil or the center in one case the lights will not light in the other case the
wires will be shorted and result in a giant spark and smoke.Unfortunately the video moves too
quickly and does not
show clearly connections,there is one shot that almost shows the bearded man not holding the cable
however the camera doesn't pan down enough to see hes left hand completely,and show its empty.
This maybe  why Kapanadze has not been killed as if we can't tell its real for sure nether
could someone looking to suppress any real world free energy devices,
on the other hand if its fake no one would bother ;D.The coils do
have a function its not for show ,Both the blue coil and the fancy coil have a function
in this device.This may give you a direction its not how the coil is wound its the length of the coil,wire length, thats an important factor.
Hoppy
Quote from: cheappower2012 on February 27, 2016, 05:27:39 AM
I think Wattsup has identified the trick but is not quite right about the method. I showed a clip earlier showing a thick black cable on the ground behind the BM and his accomplice. It would not be necessary for any cable patching to be done because this cable could have quite easily been coiled and taken straight into the device via a 'quick release' connector on the ground. The 'earth' cable could have been coiled with the power cable but left open ended, with the end clutched in BD's hand under his shirt cuff. Then reading on the clamp meter would then likely have been a little induction from the coils of power cable. The whole earthing arrangement would then have been eye candy, like most of what we see in the Aqua1 & 2 videos.
Zeitmaschine
Quote from: Hoppy on February 27, 2016, 04:20:06 AM
There is a huge problem with that opinion: A clamp meter would have shown no current with a hot wire hidden in the braid. So how did Kapanadze know for sure no one will take current measurements? A clamp meter was use on other devices before.
Not 100% sure about that. But what would be the difference? Pins 2 grounded or not?
This maybe why Kapanadze has not been killed as if we can't tell its real for sure nether could someone looking to suppress any real world free energy devices, on the other hand if its fake no one would bother
Would killing Kapanadze change something even when the device is real? It would even draw more attention to his devices. Headline: »Death by accident: Inventor killed by its own free energy device« ::)
The coils do have a function its not for show ,Both the blue coil and the fancy coil have a function in this device.This may give you a direction its not how the coil is wound its the length of the coil,wire length, thats an important factor.
This would only be true in high frequency circuits. But that transformer is not suitable for high frequencies. The device runs at 50 Hz (up to 100 Hz if a frequency doubler is used).
So then, we agree that we have some resonance and we have some high voltage. High voltage can cause corona discharge, that means - as I understand this - liberated electrons. Now if these electrons are liberated within a transformer which is in resonance with a second transformer then what could happen? Ideas?
»The electron has a much higher charge/mass ratio and so is accelerated to a higher velocity than the positive ion.«
That reads like »separating the wheat from the chaff« and then we can do something with this wheat (like routing it through a load for instance).
