0 Members and 58 Guests are viewing this topic.
Zeitmaschine
9 amps. We need therefore a magnetic field of a strength that can attract electrons from ground worth 9 amps.
Stepanov's clamp meter shows 8.2 amps, thus it works at the same level of »impossibility«.
But is it? 9 amps ground current at what ground voltage? Zero? Then 0 times 9 amps equals 0 power?
In a LC circuit the current is highest at voltage zero crossing. The stored energy nevertheless oscillates between L and C till it dissipates because of R. Interesting, isn't it?
We need all from nothing. Can't be that difficult. ::)
Hoppy
Quote from: Zeitmaschine on March 04, 2016, 06:52:24 AM
Let us know if you find out.
stivep
QuoteQuote from: SeaMonkey on March 02, 2016, 11:49:09 PM
How much DC power produced will depend upon
how close the circuit is to a commercial AM
broadcast station or stations.
the answer is: there is no DC
=... ZERO........... if there is  no rectification there is  no DC.
Transmitter and receiver  relation is  explained by Near Field   and Far Field  principals.
Antenna transmitter(TX) and antenna receiver(RX) relation is explained
by SWR principals  related directly to  physical length of the  wire  corresponding to    frequency  of the transmitter.
( another words :   physical length TX antenna must!!  be  giving   SWR  of value  1:1
!!! or close to that in  the  {path TX output} { transmission  line e.g coax}  {and antenna}.
   (SWR= or< 1:1.5 is still not so bad)  [/size]
Typically but not  always  50 Ohm is  the standard for impedances in this path.
50 Ohm is a compromise value  between the best  transmitting and the best receiving  matching impedance  ot one single antenna that  must be  build for Transceiver ( tx and rx in one - known as  walkie talkie  )
http://diydrones.com/profiles/blog/show?id=705844%3ABlogPost%3A1611361&commentId=705844%3AComment%3A1614634&xg_source=activity
QuoteZeitmaschine
Then why should an antenna not be able to catch that electricity? What's wrong? Maybe we should omit the small capacitors (shorting it).
Antenna must first resonate
- by that  we understand that  the  diameter of  an antenna must match  wavelength of electromagnetic wave of interest)
light is  electromagnetic wave (EM) too. Antenna can represent  quarter of the  wave length  of EM .
Antenna can be shortened  by adding coils so than the  length  of the coils adds  to overall physical  length and antenna still looks small.
However  the parameters  causing antenna length  matching wavelength  of the  EM , are related not to  length of the coils wire but  to electrical properties  of that "extending electrical length  coil"
- namely   coil reactive components :
capacitive reactance and inductive reactance  of that "extender"
Dielectric material   can interact with electromagnetic wave ,( focusing light lenses)
So now if the wavelength  of the wave  is as small as  visible light , we can measure  length of  one single photon ( = one period)
we would not be   able to build antenna of 1500nm for that particular frequency of light .
So now we are dealing with resonant  properties of spacial geometry.
To  understand    why it is nice and warm   in the sunny day  we need to know that photon. (any photon)    if it resonates with something  on its own path  it gives up energy,
and that energy most likely will be converted to heat.
The higher is  the wavelength  of  the photon  in the  an antenna or material acting as an antenna   the higher is  the energy  one single period.
The more heat is  than deposited on the resonating antenna.
So in sunny day  everything resonates  by absorbing heat from the sun and converting it to heat
The reason  EM of  ultraviolet light  is dangerous   is easy to explain:
Once we know that the  higher  is the frequency of the EM the  higher is the  energy of one single  period ,(= 1 photon)
Than  we have area where saturation of photons of given frequency ( wavelengths ) per  square  ruth value (= square area  or  x,y dimensions    )  is our body.
And our body  is simply not prepared to  handle this kind of heat per square  unit of measure in x/y dimension
Our receptors might not feel ( receive) information  that than will activate protective   mechanisms preventing overheating of our body cells and/ or creating  interaction  not properly handled
the reason I got bad  in my health  right after Lithuania Experiment and Colman Experiment is  most likely activity of photons of waves in the  wavelength shorter  than UV
And these  would be:
- X-ray
-Gamma
With the last two EM ( electromagnetic waves)
gamma is the "strongest  one" - ( gush I do not like the   wording  I used to describe it it.
It is  explanation  in the format directed to Idiots.)
The wavelength  of  X-rays is usually  written   in  eV ( electronVolts) however could be  expressed in  physical length  of 1 period or in  Hz.
It is just the matter of convenience.
In that  convenience we point fact that the main factor of that short EM is its energy and possibly interaction of that  energy (per period) with the matter.
Wesley
Zeitmaschine
How does St. Elmo's fire work?
It takes energy from the air and dissipates it continuously in form of light. Neither resonance nor even a metallic antenna is needed.
leo48
http://www.ktvn.com/story/31260413/13-year-old-creates-energy-harvesting-device
Maybe a 13-year-old kid is smarter than all of us who are seven years that we do not find the 'overunity
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
