0 Members and 126 Guests are viewing this topic.
Zeitmaschine
Quote from: NickZ on March 18, 2016, 02:05:43 PM
It's because your many many post of theory have not lead you to show anything working, as yet.  So, just theory remains.
Quit sitting on your hand, folks.
If I would have anything working to show, then what would I/we need still this forum for? In that case youtube would be enough to present something working including a clear diagram of it, wouldn't it?
Why do I have the odd feeling, the closer one comes to the real principle the more unrelated small talk is going on here? But maybe it's just my imagination.
NickZ
  It's not about your imagination, it's about theory without practice, (by hands-on experimentation), are otherwise just empty words.
You can think about it all you want. But, since no one knows how to build a Kapanadze device, on this thread, and there is no leader guiding the way, it's just the blind leading the blind down the road to nowhere.  Or not?
   Start to build that device that your imagination brings you, and which you feel is possible. One step at a time.
   The principals of the two circuits heterodyning to produce a gain at the output has been discussed to death.
Yet, not one device was made by any one here, to prove or disprove the point. There's no instructions, or guarantees.
    It took TK 15 years or so to develop that last device. Which looks like was built by him, out of old junk, again.
But, who knows...
cheappower2012
To Westley
I thought you were done with Tariel,interesting video.However
worthless as a means to determine how it might work,
When exactly was this video made.They did not use a clampmeter to read the
mystical Tesla currents with the device on,from the ground braid,how utterly stupid.
The big coil in my opinion does nothing,but create
the illusion its a Tesla invention,people believe Tesla is a god
this throws the investigation from Tariel to Tesla.The black box plus the small white
wire coil are the key components.Tariel did attempt to infer that the big coil is
important,yellow wire windings.He did ran an inductive load ,the fan which is good,its line frequency at 220 vac.
The 9 battery is interesting as its a super heavy duty battery not an alkaline
as the alkaline battery can source a lot of current ,the super heavy one can not.
This indicates the start up does not need a lot of current, it could be activating a relay,to activate a larger battery to start the device
in the black box.I'm not saying its fake,as using a 9 v
battery to start it
is to indicate it has no batteries powering it,it may need a much bigger battery to start up.
Two of the black modules appear to be fake,the one
nearest the large coil is real but if its to generate a spark it does nothing to generate the current.
The problem with this video is the same problem a person
investigating a ufo defying gravity ,you may prove the ufo photo or video  maybe real,now explain how it defys gravity
by what theory,you can't do it.This video shows the device is possibly real but worthless as
a tool to figure out how it works.Theres is far too much hero-worship of Tesla here
this sets people on a wild goose chase.Tariel and hes clan remind me of lying gypsys,doing palm readings and ripping people off giving them nothing.
verpies
Quote from: cheappower2012 on March 18, 2016, 04:38:33 PM
When exactly was this video made.They did not use a clamp-meter to read the mystical Tesla currents with the device on, from the ground braid, how utterly stupid.
...but that clamp-on meter reading on the braid kind of proves, that the device is not supplied by a hot wire inside the braid.
Tariel and hes clan remind me of lying gypsies, doing palm readings and ripping people off giving them nothing.
How do you think he faked this one?   If he did, he is good... isn't he?
BTW: A chemical battery inside the aquarium would not last that long with these loads.
cheappower2012
Verpies
Quotebut that clamp-on meter reading on the braid kind of proves,
The device is off when he uses the clampmeter,when he starts it up he uses hes tongue
as a test instrument ::).At no time did he take a clampmeter reading to show  current  or no current with the device on,since the belief is its a Tesla invention
a no current reading indicates a  lack of mystical Tesla currents.
A lack of current indicates its not part of a circuit connected to the grid it also calls in question why does hes device needs a ground at all.
QuoteHow do you think he faked this one?   If he did, he is good... isn't he?
I believe its real,however I don't believe it has anything to do with Tesla.
A larger battery could never power the things shown,it would be used to start the device once started its looped
to self run,at that point the larger battery is not used.He uses the 9 v battery to show that
doesn't use a battery.A good test would have been a oscilloscope picture,taken at the voltage output of the device
as this would be an indicator of a great amount of information,such as the frequency,peak to peak voltage,
more important is the 50 hz a sine wave a square wave or a modified square wave.If its a sine wave
then either its a grid tie or hes using a sine wave oscillator,if its a square wave or modified
square wave then its artificially locally  produced so mostlikely real.In my opinion it operates
outside of  known electrical theory its a kind of current amplifier,its not a
free energy device but a kind of converter of an unknown energy source into electrical energy.
Without a half ass theory of operation theres no chance of a sucessful replication,since
Tariel will never give up the secret.Using known methods of electronic theory it has to end in failure to figure out how it works.
