0 Members and 144 Guests are viewing this topic.
Zeitmaschine
Quote from: Mancha on March 19, 2016, 03:15:52 PM
I do not see reason for ground connection at all, but if it is realy important, on the end they said  can not switch off device  so quick, they need to hold taster longer. Why the did not disconnected ground than, it will be faster ?
Because if the ground of the device is suddenly not connected to earth ground then it can give an electric shock while the device is still running?
Quote from: Meta on March 18, 2016, 07:53:12 PM
Finally the experiment with a power strip, to show that the Ankh powers itself. I dont think its a trick. I think that power strip has no safety switches, caps or breakers in it to keep the strip from working as an Ankh. I tried it on my modern power strip and it didnt work.
http://geekologie.com/2012/03/plug-a-powerstrip-into-itself-for-free-e.php
We don't fall for crude youtube tricks any longer.
Quote from: stivep on March 18, 2016, 02:08:58 AM
https://www.youtube.com/watch?v=3urK7ybyyZM
Wesley
And also we don't fall for fancy wound coils any longer. Someone should tell Kapanadze.
So as we can see (or not can see), the real device is rather small; it is in that black box and it has to work with a few simple components like that one under Stepanov's cardboard box. One transformer to get the basic OU effect ... and maybe another one for the back loop.
Mancha
Zeitmachine
[/quote]
What you are saying makes sense to me.
Best
cheappower2012
Zeitmachine
The small coil is not eye candy it plays a big part in Kapanadzes device
.You are wrong if you think the current  comes from the black box,the black box creates conditions to cause the
coil to create the current,but is not the source of the current.A very hard concept to get but your getting there.How the coil is wound is not important,however the length(how long the wire is) is very important
another very hard concept.As to Stepanov's device,hes device is not looped its used as a reducer of current drawn,there are too few video's,I don't say its fake,however in comparison to Kapanadzes device its very weak.There may have been a lot of other inventions that operate like Kapanadzes but there very little information to research.
Keep going don't let the skeptics derail you,there is coming a time
in the near future where the skeptics will have egg on there faces and will shut there traps.
Meta
"We don't fall for crude youtube tricks any longer."
__________________________________________
Do we also ignore the circulating electricity in the Perpetual Motion Holder (PMH example), which is very similar to the circulating electricity in the power strip?
Meta
I can wind a toroidal coil that cancels all electric and magnetic readings on a meter leaving only higher energies. What do you say to that.
