0 Members and 52 Guests are viewing this topic.
Meta
Westley,
I should have sent this to Roberto, rather than you..my error. Im referring to his TMT system he mentioned.....
What transmitter, you ask? This one....
"2 - Few years agò I tested a complex ONE TO MANY TMT system (1 x transmitter and 6x receivers) just to check existance of possible power multiplication at the combined receivers end.  Even if I noted some interesting facts...I failed to obtain in output more energy than the supplied input."
____________________________________________________________
If you would have stepped the transmitter's 3D voltage up into the 4th dimension using a transformer, then stepped that 4D HV, HF back down again using another transformer, to 3D again, you would have multiplied the output, just like Gerard Morin did. Im sure of it.
stivep
Quote from: Meta on March 21, 2016, 01:01:58 AM
I  will try to  explain where  is that I get lost:
QuoteIf you would have stepped the transmitter's 3D voltage up into the 4th dimension using a transformer
1. what transmitter
2 what frequency
3. what is the power
4. what is the modulation or it is unmodulated carrier
5.what is 3D voltage
6.what is 4th dimension
7.what is  the property of each of the dimension causing it to be significant.
8. how would you specify potential difference or any other properties that could be reached  by going to 4th dimension.
Quoteback down again using another transformer, to 3D again, you would have multiplied the output, just like Gerard Morin did. Im sure of it.
9.  why do we need to jump between dimensions.
10. what kind of multiplication do you have in mind give me  measurement units. e.g Watts / Jules / Coulombs / and so on
11What is significant in similar kind of behavior between Gerard Morin and your experiment.
11a. what is gain energy coming from?
12. attach the drawing or the schematic  of the practical arrangement of your  experiment setup.
Please provide answer to the questions without being send  to literature to find the answer by myself.
However links are appreciated as well.
Wesley
pix
Quote from: Meta on March 21, 2016, 12:50:47 AM
acca,
Kapanadze's device doesn't seem to have any antenna to pick up the spatial potential like a Moray device or Tesla's Black Box powering his car. I think Moray and Tesla used a series of step down transformers to bring the extremely high spatial potential down to usable levels.
Yes Meta,
That is what Kapanadze is doing.
Zeitmaschine
Quote from: cheappower2012 on March 19, 2016, 04:46:03 PM
How the coil is wound is not important,however the length(how long the wire is) is very important
Then is it also important how long the wires/cables are between the device (fancy coil) and the load?
Quote from: Meta on March 19, 2016, 06:45:02 PM
I can wind a toroidal coil that cancels all electric and magnetic readings on a meter leaving only higher energies. What do you say to that.
Show me.
Quote from: Meta on March 19, 2016, 06:24:37 PM
Do we also ignore the circulating electricity in the Perpetual Motion Holder (PMH example), which is very similar to the circulating electricity in the power strip?
The holder stores energy, it does not continuously dissipate it like the bulb on the power strip.
Where can I see a (self-running) free energy device built by Gerard Morin? ???
Do we need two transformers? If we have a 3-phase (or even 2-phase) step up (or step down) transformer, then can we perhaps step up and step down voltage with one and the same transformer at the same time with a single magnetic field?
:P Just an idea. I think Stepanov uses the second transformer in the carpentry setup only to distribute the energy between the three phases.
And so far ionization (of a transformer winding) is the best explanation where the extra energy is coming from. The ionization connects to the medium (aether) and therefore it can collect additional energy from that medium. Maybe we can call that medium also the 4th dimension; it does not really matter.
Meta
Quote from: pix on March 21, 2016, 02:49:10 AM
Yes Meta,
Are you sure this is what he's doing.
I dont see a line of transformers in Kapanadze's device.
He will need from 2 to 12 transformers to bring extremely high spatial potential down to usable levels. Thats why Morays box was so long, hum?
