0 Members and 211 Guests are viewing this topic.
romerouk
@woopy
excellent work. Try for the first time without any capacitors, careful adjusting the spark gap.When use ac without capacitors the distance is very small.Also try with a capacitor 0.1uf in parallel with the output , before the spark gap.Use at least for one of the grounds  copper pipe.if you have a high voltage capacitor connected in parallel with the load, 0.01 - 0.05uf.
Maybe you should have started with normal bulbs first
I think today we have a winner here...
Success
romerouk
@woopy
One more thing, make sure you are outside and all most important electronic and electric equipment in the house is off, unplugged.
Quote from: woopy on June 15, 2010, 12:19:54 PM
Hello romero and all
OK i am almost ready for a first test
I did the coil exactly as Romero  that is  84 turns  plus 22 turns plus 6 big turns.
the coil 1 and 2 have the same stranded wire (blue) and  for the big coil (green and yellow) there is 7 strand of plain copper,
the center is made with 4 stranded copper and something torsaded for connection to one ground line, plus the main blue wire connection to the spark gap.
the mot is rated 700 watts. I will use it directly (without the cap and diode for a first test. What do you think ? Or can i use the MO cap  (0.95 micro farad and 2100 volts) and HV diode.?
I will ground it with 2 ground line conducting to 2 galvanised steel bar going 1 meter deep in the ground. and separated about 15 meter.   I intend to use a wire with 3 time 1.5 mm2 bounded ,for the ground lines .
I intend to begin with a halogen 500 watts what do you think ?
If it works, i will post the pictures of the construction of the coil step by step.
good luck at all
Laurent
Very nice setup woopy. Are you using a ferrite core, the picture seems to indicate that. It would be nice to have a moveable core, it's one way to do some kind of tuning and see perhaps different results by moving it in and out.
starcruiser
Quote from: aether22 on June 14, 2010, 09:16:33 PM
My point is that you just need a flux source nearby, it does not really need to be part of the device as such.
I would be interested in replicating your setup probably, and details would be appreciated, just and length of main coil, wire gauge but mainly details on the oscillator.
This simple experiment MIGHT be even more important than Kapagen, of course there is much to test first.
FLUX SOURCE..... MAGNET?????
Regards,
Carl
xenomorphlabs
I am wondering about the quality of the actual earth surrounding the copper pipes.
I have a little spot with trees next to my house, i have been digging 2 holes 60 cm deep, but the peculiarity of that spot is that there is the basement of a ruin under it and someone just put a layer of maybe 20 cm peat or something like that over the rubble and many trees and plants have grown there.
The question is really if a good ground for these kind of devices necessitates a relatively unobstructed "access connection" to telluric currents or if it´s merely a source of electrons if there is enough earth surrounding the rod.
Also even though the rods are at a 10m distance with an unmeasurable resistance between them, is there actually current flowing between the two?
This whole topic is really not as intuitive as electronic circuit theory hehe.
I did manage to get an earth battery going there, but that had only a distance of maybe 80 cm between the electrodes.
