0 Members and 73 Guests are viewing this topic.
verpies
Quote from: Meta on March 21, 2016, 12:30:42 AM
A "dimension" is defined by all of Science, as "a 90 degree rotation of an electron". Meta
Hey, you started it, so let me ask you first how you can demonstrate your claims without using more words.
Meta
Westley,
"do not drag me there...
This is for me unacceptable form  of  wasting my time.
Charlatans have been working hard to  their own benefit based on facts that are  mixed together  fights with dragons and holly wars, killings  punishments an angels with swords ."
_____________________________________________________________
I hate religion more than you do. I dont go into religion but you have to understand that the ancient religion was science in ancient times...it was all a super-science and then some priest made a religion of part of it so we have to acknoledge it occasionally then bypass it.
verpies
Quote from: stivep on March 21, 2016, 01:22:42 AM
What is 3D voltage
Although I do not subscribe to the idea of such "voltage", by semantic analysis a "3D voltage" would be an electric difference in potential, that can be completely described by three independent numbers.   By "independent", I mean that any one of these numbers can be varied without affecting the two others.
6.what is 4th dimension
It can be a mathematical dimension as in the equation ax3 + bx2 + cx + d, where the coefficients a,b,c,d can be varied independently of each other.  As such, that equation is 4-dimensional and e.g. the coefficient "d" is a 4th dimension in that equation.
A dimensionality of an abstract Euclidean geometry can also refer to the minimum number of coordinates needed to describe position in it or the maximum number of lines that can be mutually perpendicular to each other.
In such geometry, the 4th dimension would be the direction along some 4th line, that is perpendicular to the remaining 3 lines , which are also mutually perpendicular to each other.
In a 3D euclidean geometry, three 1D motions can occur parallel to these three orthogonal lines, without effecting each other's magnitudes.  The orthogonality of such motions guarantees their independence.  That's why the axes in a 3D-printer are all perpendicular to each other.
If one of these motions was not perpendicular to the others ( e.g.:  at an 89º angle ), then it would affect the magnitude of the remaining motions and the their independence would be lost ....because cos(89º)>0.
BTW: We commonly measure motion as space divided by time, with units such as kilometers per hour (km/h) or miles per hour (mph).
7.what is  the property of each of the dimension causing it to be significant.
The defining property of a dimension is its independence from all of the remaining dimensions.
Of what is the magnitude of each dimension in a "3D voltage"? I don't know - you'll have to wait for Meta to answer that, but whatever the answer, these magnitudes must be independent of each other.
ALL OF THIS IS ELEMENTARY but could not be communicated without words to convey these concepts. Especially on a forum, such as this, where words are the primary means of communication.
I'd like your feedback whether you understood these words.
P.S.
The rest of your numbered questions refer to NON-ELEMENTARY concepts, which are not mine, and I will not endeavor to answer them.
Meta
Westley,
I already posted Morins video and my MetaQEG.pdf for everyone but I'll do it again for you. Why do I
have to do things two or three times? Those posts will be after you make me answer all these
unnecessary questions that are answered in Morins video and in my Addenda page 2 and 3 of the
MetaQEG.pdf.
_______________________________________________________________________
I  will try to  explain where  is that I get lost:
    If you would have stepped the transmitter's 3D voltage up into the 4th dimension using a transformer
1. what transmitter
The TMT transmitter of another poster I erroneously sent in your direction.
2. what frequency
Frequency of the solution? HV, HF RF...15,000 v, unknown freq, no instrument measuring Morins freq
3. what is the power
Power in watts....In- 1,500 watts, Out- 6,500 watts
4. what is the modulation or it is unmodulated carrier
No carrier in 4D, space is the carrier?
5.what is 3D voltage
120v in, on the low side of transformer 1
120v out on the low side of transformer2
15,000v between transformer1 and 2, horns on top.
The dimension following our 3 dimensions, simple....only they come in sets...1,2,3 and 4....5,6,7, and 8
The higher the HF, RF and HV reached in 4D, the more electricity is produced when stepped back down
to 120-240v.
8. any other properties that could be reached  by going to 4th dimension.
All other miraculous phenomea is available from 4D upward...invisibility, Tesla shields, beam weapons,
space-time anomalies, matter changes, Hutchison metal breakdown.....
    back down again using another transformer, to 3D again, you would have multiplied the output, just
like Gerard Morin did. Im sure of it.
9.  why do we need to jump between dimensions.
That's where the spatial potential is.
That's the source. The Dirac sea.
10. what kind of multiplication do you have in mind give me  measurement units. e.g Watts / Jules /
Coulombs / and so on
1,500watts in, 6,500watts out.
It depends upon the Kw rating of the two transformers
11What is significant in similar kind of behavior between Gerard Morin and your experiment.
Gerrard starts in the 3rd dimension, then jumps to the 4th then comes back down to the 3rd.
I bypass the 3rd, nullifying it and go directly to the 4th and extract the potential directly in the
MetaQEG.pdf
11a. what is gain energy coming from?
Space energy already existing, eternally open to the dipole battery terminals.
12. attach the drawing or the schematic  of the practical arrangement of your  experiment setup.
Im gonna make you read and listen now..
MetaQEG.pdf
Morins set up
Free Energy Feb 2015 The Doubt about OverUnity is Over Gerard Morin
https://www.youtube.com/watch?v=DROoUg1Hio8
Meta
Westley,
Metaphysical Cosmology is the branch of metaphysics that deals with the world as the totality of all phenomena in space and time. Historically, it has had quite a broad scope, and in many cases was founded in religion. The ancient Greeks drew no distinction between this use and their model for the cosmos. However, in modern times it addresses questions about the Universe which are beyond the scope of the physical sciences. It is distinguished from religious cosmology in that it approaches these questions using philosophical methods (e.g. dialectics).
The information is error.
First there was Cosmology, the beginning.
Then Cosmogony, the process of toroidal SELF creation, no creator required.
Then Mythology was created to symbolize Cosmogony's story...
Then Religions were derived from Myth,
And now we have forgotten the source, Cosmology...
Ive studied all of this for 40 years
