0 Members and 173 Guests are viewing this topic.
pix
Quote from: Meta on March 21, 2016, 06:13:42 AM
Are you sure this is what he's doing.
I dont see a line of transformers in Kapanadze's device.
He will need from 2 to 12 transformers to bring extremely high spatial potential down to usable levels. Thats why Morays box was so long, hum?
Yes, I am sure.
There is no other explanation. There is clearly a Tesla coil and Kapanadze says pointing at the top of it " here we have a lot of energy".
White stuff a the bottom of the box is step down transformer.
Also, there might be another trafo in the mysterious box in the corner.
You don't have to use metaphysics to understand energy accumulation properties of Tesla coil, that manifests itself as a high voltage. Step it down to useable level.
Meta
Yes exactly..
"In such geometry, the 4th dimension would be the direction along some 4th line, that is perpendicular to the remaining 3 lines , which are also mutually perpendicular to each other."
_________________________________________________________________________
Heres what I derived...
The three perpendicular directions; height, width and length, is easy to calculate and see....however the 4th dimension is hard but not impossible to see....it is, as he says, perpendicular to all the other 3, so what direction is that?.....
It would be a line that starts from the center of the other 3 and moves outward to any point outside the circle of the other 3......and it would also move from any point outside, back to the center...so its a conscious energy that moves in, to 0D and out, to 4D. Thats the only direction perpendicular to all the other 3 directions.....it means that the energy can be 4 or 0...the center...and as you know, 0 represents 0-point because the center started as 0 then 1, 2 and 3 perpendicular directions.
4=0 so it is a loop of 2 directions
0,1,2,3,0...1,2,3,0
Its saying when we reach the 4th dimension we reach the 0-point of energy.
So it looks impossible to go from 3,2,1,0 so we get there by going to the 4th instead.
Get it?
Meta
Quote from: pix on March 21, 2016, 08:00:11 AM
Yes, I am sure.
Very interesting....keep me updated?
Tesla coils are high frequency, high voltage arent they?
And remember, Morin says all AC is RF (Radio frequency) so you will not have any AC reading on your low voltage sides but if you used a RF detector you would see the high RF.
pix
Quote from: Meta on March 21, 2016, 08:10:28 AM
No, originallyTesla didn't operated above 30kHz.
The higher frequency, more energy is lost in eletromagnetic radiation.
The point of Tesla coil is to accumulate energy.
Hydraulic analogy: how are you going to increase pressure in your pipe, if pipe has a lot of holes and leaks?
NickZ
   Meta:
   You quoted:
"Metaphysical Cosmology is the branch of metaphysics that deals with the world as the totality of all phenomena in space and time".
    Good one!
   If we are to obtain a self runner, knowing what one is doing to extract the illusive "extra" energy into a device is an important consideration. Considering how this energy can be tapped is not just a detail.
   Science deal with what it can see, touch,  and measure. Not with what I can't. But, in this process, considering that this energy can't be measured, science just neglects it.  To neglect the SOURCE of everything we see,  and that which can't see, simply because we can't measure it, yet, is not a sound approach.  Especially for a free energy device that works by tapping this unseen and as yet unmeasure-able force.
   Verpies:  If you are interested in seeing the video that Igor Moroz made showing the lighting of 2000w worth of bulbs using an induction cooker circuit going to a single thin magnet wire to the bulbs, please look for it yourself, on youtube under Igor's channel.
   The point was that it can be done, and made to look like magic, as the wire is not visible. This has nothing to do with
TK's system. Only to point out that it could be done in that way, without burning out the single very thin mag wire. As the magnetic current does not go through the wire, but around it, such as with the "skin effect" instead.
