0 Members and 79 Guests are viewing this topic.
Zeitmaschine
Quote from: Meta on March 21, 2016, 01:56:46 PM
If you noticed, on a pole, the high voltage comes down from the top three lines then into the horn of the pole transformers and out the low voltage terminals on the side....The voltage never goes from transformer to another transformer so the power companies are not creating overunity conditions.
Why not, if it is that easy? :D
Quote from: stivep on March 21, 2016, 12:38:00 PM
5. Transformer from picture  below was manufactured  by http://shinhom.manufacturer.globalsources.com/si/6008811401077/Homepage.htm
Q5  can you  provide us with model number of that transformer ?
Interesting. Exactly this model number is needed to give us free energy?
It's called a »3-axes Transponder Inductor and 3D RFID Transponder Antennas, Suitable for Radar Location System«, hmmm ...
Quote from: pix on March 21, 2016, 12:03:12 PM
Nowadays,for operating Tesla Coil spark gap is an option. Solid state switching could be used. Spark gap, if used, might be hidden.
But it isn't hidden, it's in plain view, but not working (like that spark gap in 2004 video).
Meta
"Meta has send 3D transformer ( attached picture)"
_________________________________________
No, I did NOT...Ive never sent a drawing of the counterbary toroidal coil to anyone.
That coil picture is not my coil.
I do describe throughly, how to make it, on page 2 or 3 of the document MetaQEG.pdf
Meta
"Q2:  what  went wrong in your cooperation  Meta with HG?"
__________________________________________________
I tried to be forthright with that bunch of Mellinials but they sent Ed Weatherall to make a pdf of my circuit called MetaQEG.pdf and then he dropped me like a rock with no cooperation after that...they just wanted to steal the idea....they are a deceitful bunch...now I tried to get the info to Jamie but they ignored it and went another direction so I dont deal with them any more.
Mr MileHigh knows nothing of my coil or ideas. He's just a libeler.
Ive read 39,500+ books in 18 years at 6 books a day, Ive studied 12-15 hours a day at that time and Im still researching every day since then. Ive been over every aspect of every science and religion that exists. I have a very wide base of knowledge. Beardens circuit is a product of that research...not to be taken as lightly as he suggests..hes a clown.
Meta
"Tipically my small TMT generated about 3 - 5KV @1.6MHz on top of secondary coil."
________________________________________________________________
You did something different. I think your transformers were not big enough to reach Morins voltages between the horns thru the secondaries. He used 50 Kv and a 25 Kv transformers.
Meta
Either they have not caught on to the trick or they will never reveal the trick openly.
You can also use that trick, when the power goes out and you have no electricity...all you have to do is place a small generator at the bottom of a pole that has two pole transformers on it. Get your climbing gaffs on and take a dual wire from your small generator at the base of the pole, that you placed there, and hook the wire to the low volts side of one transformer, after you disconnect the high volts wires coming down from the three wires above, at the very top of the poles. Now connect a heavy wire from one horn of the first transformer to the horn of the second transformer and then run a dual wire down the pole from the low volts side on the second transformer and you have just created 7x the power for your use, until the regular power comes on again. When regular power come on again, disconnect all your wires and leave..................
