0 Members and 60 Guests are viewing this topic.
Zeitmaschine
Quote from: NickZ on March 24, 2016, 01:44:36 AM
Some years ago I asked why has not a single person on this thread replicated or even tried to replicate at least their version of the TK device(s). And Verpies answered, that there is not enough information just from looking at the video, to know just how it's built, to be able to replicate it properly.
Then here the question would be: What is enough information? What exactly is it that we can't see in the videos? What if all information is there already but we are just to stupid to put it together?
I took his advice and moved to the Daly thread, instead. There I've been ever since. Because of Ruslan and his videos, and diagrams, and explanations, along with Akula's ideas. Which there is some information on.
What if that information is false? Doesn't the Ruslan device contradict the lack of information? Where did Ruslan get his information from how to build his version of the device?
And up to now we have not found even a single diode out of place, that could lead to calling any of those devices fakes. At least on the Ruslan videos, and schematics.
But a time ago I have found a reflection out of place (see image and video below). Here Ruslan's mistake is the same like with Kapanadze's spark gap: If that high voltage antenna coil is causal responsible for the energy output of the device then disturbing that antenna's function by means of a screw driver must make the light bulbs flicker. But they do clearly not react to that disturbance of the antenna.
So this looks suspiciously like a fake device. I don't know how he did it, but maybe he deleted the hot wire by means of a video editor. Those videos are always looking like quickly taken with a mobile phone and then uploaded to youtube straightaway. But who knows? There could be easily some editing between, especially when the video is taken by one single person without any independent witnesses.
The other problem with Ruslan is that he builds one device after the other, all looking basically the same. I can see no real development here. If I would have a working experimental setup then my next step would be to make it usable in a more practical way, like putting it in a small box in order to make handy presentations in front of real people (not just on video).
On the other hand there's No schematics, no diagrams, nor any idea what's inside the black box, or how the driver circuit really works, on the TK device, such as he's showing on his last video, or on any other one he's made or shown previously.
What is a driver circuit? I can't see any electronic circuits in the Stepanov videos, and I don't think there is a lot of electronics hidden in Kapanadze's tin can. Also it has to work with components available in the 1930's. And I would also guess that the mysterious Moray Valve was nothing more than a simple semiconductor diode bridge which was not common in those days.
I'm not suggesting that you give up the search for free energy. I'm just suggesting that one should build what there is some info on, and not try to build what there's little to no information on. Of course it's up to you.
I think it is better to look at little but real information instead at some but false information.
On the other hand: If the Ruslan devices (and some others) are fake then this could be second hand evidence that the Kapanadze and Stepanov devices are real. Because why should one go through such lengths building phony devices without good cause? The reason would be, because someone told him to do so in order to distract the forums from focusing on the real thing.
Quote from: verpies on March 24, 2016, 05:32:38 AM
It is you who wants to prove that such fast power switches are available, so the burden of proof is on you.
Doesn't matter. Why should we need fast power switches?
P.S.
Press the "Quote" icon if you want to quote my posts.
Maybe he can't see that icon from the vantage point in his parallel universe. ;D
verpies
Quote from: Zeitmaschine on March 24, 2016, 05:40:10 AM
I did not write that we need nanosecond/picosecond SPDT switches for Kapanadze's replication.
It is Meta who needs them for his design.
Quote from: Meta on March 21, 2016, 07:31:59 AM
MetaQEG.pdf:
The fast switch - Incorporated in the switch are the two single pole/double throw switches. This one Fast Switch chip
must be rated at the Relaxation time of the electron. This is far faster than 1ms as designated. It should be in the GHz or
nano/picosecond range...
It is well know that ESR frequencies are well into GHz range, which yields periods below 1ns.
Meta
This search page does not list any bilateral switches capable of switching on&off faster than 10ns, that that can conduct appreciable currents and block high voltages. e.g.: at least 1A, 50V.
______________________________________________________________
I mentioned, already, that this MetaQEG doesnt deal in physics.
The battery is only a gateway to metaphysical spatial potential with no readings of voltage or amperage. Dont charge the battery.
verpies
Quote from: Meta on March 24, 2016, 05:54:06 AM
Does it deal in reality or practicality?
Meta
There are two sides to the Universe, the
Reality- The invisible, virtual, mind world of potentials.
Actuality- The world that is actually seen and visible.
Both of them are practical. One needs the other. One can do nothing, it takes two, baby.
