0 Members and 159 Guests are viewing this topic.
stivep
http://farside.ph.utexas.edu/teaching/302l/lectures/node34.html
this link may help to understand mechanism of electrostatic potential./
when you read it it is easy to understand with  quite simple language used in it.
there is an explanation of every symbol that is used there  and best off all it  clearly shows you how static electricity works
There is given XYZ coordinates inside  the sphere.
when you  look at the  figure 14  look at  it as sphere with the center , and from that you will see
- X
-Z
- vertical Y - is the line( starting from point strait to your eye)( top view)
exactly  try to see it in 3D form slices of the sphere
So now you ask  what do I need it  for?
it is concept of Electrostatic Pump  Phenomena
Well ..........I assigned electrostatic potential difference as   primary  reason- force of electrons being pumped from the ground  .( /TK/Akula/ Ruslan/ Vasmus/SR/)
Let's say for the moment that I'm right in my thoughts.
Than you have foundation  and you can build anything that can push you forward in your experiments.
You have  pumped "medium"- electrons from the ground[/size]
You have driving force - electrostatic difference - (the attractive one for electrons from the ground)
You can  think of  electron inertia  between intervals of  stimulating impulses from  nano/ pico/ second  stimulating impulses .
You can think of electron density  in form of  questioning ..why?-Ruslan , Akula, and TK( in big power devices) are using very thick copper as a ground wire.?
the example of 15 girls ( 15 years old) pushing the car
and after the while, there  is need only for 1 girl to sustain the losses.
after another while, there is a need for one finger of one girl ( pushing) to sustain the motion and compensate the losses.
1. In Kapanadze, Akula, Ruslan Anominus, SR, Vasmus, devices there was always  initial source of energy to start the  device.
So the first push of 15 girls = initial  energy at/to start.
2. electric motor ( not under the load) obeys the same  requirements. initial  energy at/to start.
3. flywheel ( not under the load) obeys the same  requirements. initial  energy at/to start.
4.Since  after that   device/ motor  has started than there is accumulation of kinetic energy  in  it. Than very small source is  enough to  make it run
( one finger of one girl))
If than we use  load that takes more energy that is compensated by ( one finger of one girl))  than  anyone of the devices listed  above will start to lose its kinetic energy and eventually it will  go to the full stop.
Now we have  logical conclusion that
energy used= energy compensated  just to keep device in perpetual motion under  the load.
It is good for us that :
That conclusion is not true  when "additional energy" source is being controlled by   our ( one finger of one girl)).
So lets provide list of forces we are talking about so far:
A- initial source to  start  and accelerate  (15 girls/ or  12V battery .)
B- compensating  force  ( one finger of one girl or any small source)).
C. -the "third source" - external energy that  is controlled  by B force.
conclusion :
1.now the B force is no longer compensating force but is controlling force.
2. now that B force can take advantage of controlling  electron flow from the ground
!!So instead  of just concentrating on  looking for  C force  we can look at any force that can be controlled by B force.!!!
The little bit original would be just to  think:
How much force  B you need to  push button  to  run the engine?
How much force  B you need to  control valve  in the pipe with  flowing water.
the success if  slave system in USA  at very history of US was : little force used to control  army of work force that did not have to be  paid for,
The modern form of slavery is to get more than it cost.
And that is the goal of FE.
get more  than ... it cost you.
In  that USA early feudalism  - self-looping was made by slave close loop  at no cost to the slave owner.
I need to finish  now  this article.
Beta particles  energy sources are being used as power supplies for space  satellites.
Assuming that   in concept of
Electrostatic Pump we use inertia of electron flow from the ground
the one finger of one girl could be compared to any energy that we do not have to pay for used as stimulating energy for the electron flow.
This article is just skeleton  and does not have body yet.
You can use it to build the walls around the skeleton and new interior.
You can alter  it   but it is good to have something solid -a foundation.
Wesley
NickZ
   Zeit:
   No drivers on the green box video, either?  Check to see what those two transistors are doing there, in the video below.
Eye candy, as well?  https://www.youtube.com/watch?v=X1Np8n_etUs
  After that Tariel didn't really show what is driving his coils.  But, those coils don't just drive themselves, without a pulse circuit, and/or a spark gap, in most all of his devices. It still may work as simple as he says it does. Unlike Ruslan's last device, with all those components.
  You said, "There is a certain similarity. But after a closer look it is different. The high voltage antenna (on the right) should actually be the output coil".
   Well, that antenna coil on the right serves a different purpose, but if connected as in the diagram you posted it would be the same. However that antenna coil on the right is the output coil, for the HV circuit. Which by induction is then stepped down through the 168 turns coil windings, that are part of the grenade coil that is just under it.  This also makes it possible to light higher wattage incandescent bulbs, not just CFL, or LED bulbs, at the grenade's output coil.  However, that is not the whole purpose of that set up, nor explains how it self runs.
   All the Tesla diagram circuit you showed will do, is step down the HV by the third coil, so that it will light the smaller incandescent bulb. But, as there is no feed back circuit, that device will not self run. Nor was it meant to, nor provide free energy.
Zeitmaschine
Quote from: NickZ on March 25, 2016, 01:21:41 PM
No drivers on the green box video, either?  Check to see what those two transistors are doing there.  Eye candy, as well?
Those transistors are the same ones as seen in the 2004 video (blue-orange coil). And shocking what a surprise: Each of them is connected with only two wires. How can a transistor work as transistor that way?
After that he didn't really show what is driving his coils.  But, those coils don't just drive themselves, without a pulse circuit, and/ or a spark gap, in all of his devices.
But Stepanov shows what is driving his coils: a) the grid (can be replaced by an inverter like Kapanadze did) and b) by a frequency doubler circuit.
The two drivers are the grid and the frequency doubler circuit. Why should we need more?
Well, that antenna coil on the right serves a different purpose, but if connected as in the diagram it would be the same. However the antenna coil on the right is the output coil, for the HV circuit. Which by induction is then stepped down through the 168 turns coil windings, that are part of the grenade coil that is just under it.
Then you are saying that the Ruslan device works but the similar drawing above will definitely not? Strange.
The issue here is this: Can Ruslan make a three-phase device? Kapanadze can and also Stepanov can. That automatically means, all over-complicated setups are out of the picture.
A small consideration: What did Kapanadze prior to his discovery of that OU-effect? What did Stepanov prior to his discovery of that OU-effect?
Best answer so far: They experimented with three-phase power factor correction methods - not with Tesla coils. Thus the solution to all this has to lie in a simple three-phase transformer.
And here comes another OU inventor working coincidentally with three-phase devices and machines.
leo48
QuoteThose transistors are the same ones as seen in the 2004 video (blue-orange coil). And shocking what a surprise: Each of them is connected with only two wires. How can a transistor work as transistor that way?
could be two diodes
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
NickZ
Quote from: Zeitmaschine on March 25, 2016, 02:40:56 PM
   Zeit:  Yes, I'm saying that the Tesla coil with a third coil is not a self running device. It takes input power from the grid or from another power source to provide for any output it may have. Just like any normal circuit does. But, will not run by itself, as there is no feed-back path, as mentioned.
   The Ruslan/Akula/TK devices are self runners. They are not just an inverter, like your previously posted diagram
