0 Members and 94 Guests are viewing this topic.
Zeitmaschine
Quote from: NickZ on March 27, 2016, 10:46:27 AM
This video has me baffled.
https://www.youtube.com/watch?v=qi1SdKAiK1E&ebc=ANyPxKrJj98oBQI8H8UMlNAouv8zL1EMJ1dPmmXJtXbao8eIo6aKxTaun1FU5djpbSJdtPaVyzn83THzQ1DIei98adeISDjqzw
All I can see here is some loads running on a battery. No measurements, no schematics.
Maybe he should use a frequency doubler circuit between his coils for improvement. :P
Quote from: NickZ on March 27, 2016, 11:46:06 AM
Is buying a $15 PS to be used for the (external) feed back loop, more complicated, than making a home made one and putting inside of the box?
Since Kapanadze is not a specialist in electronics, I think a home made one would be more complicated.
Why step down the 220 volts AC high current output of the device to 12 volts DC, then supplying an inverter with that voltage and then stepping up those 12 volts DC to 220 volts AC again? In order to get a 50Hz reference?
When Kapanadze starts his small devices with a 9V battery then what is the output frequency? 50Hz? Or some arbitrary Hz? Arbitrary here means the self-resonating frequency of the device, which could be anything a light bulb or a heater can run on.
Here Kapanadze starts a three-phase device (that runs a three-phase motor) with a 9V battery, but he needs two suspicious large boxes for that. Why? Because a self-resonating coil at any arbitrary frequency can't drive a three-phase motor, so he needs additional equipment like a hidden 50Hz inverter and also a hidden 12V battery in order to start that inverter?
The meaning of this: If the goal is to run a simple incandescent light bulb or a heater and without the need to measure the frequency (like done in green box video) then the output frequency of the device does not matter. If the frequency does not matter, then a self-resonating coil or transformer would be sufficient and thus the size of the device can be minimized because there is no need for a large (frequency stabilizing) inverter.
Meta
Void,
Please tell us how this is not happening....
Free Energy Feb 2015 The Doubt about OverUnity is Over Gerard Morin
https://www.youtube.com/watch?v=DROoUg1Hio8
Meta
Void,
Please show us your superior technical skills in scientific language and examples of your own overunity device.
Void
Sigh... Meta, I am not making any claims of knowing how to produce OU...
At least not yet anyway... ;)
Meta
Void,
So what the fuck are you harrassing me for?
You still have to look at Morin's video and explain how that can't be done.
