0 Members and 279 Guests are viewing this topic.
vrand
Quote from: woopy on June 15, 2010, 12:19:54 PM
Hello romero and all
OK i am almost ready for a first test
Nice work Laurent!
Looking forward to your tests.
If your ground is too dry just add water around the ground rods.
Regards, Mike R.
e2matrix
Quote from: romerouk on June 15, 2010, 11:51:43 AM
Sorry for the mistake, the total is 7.5 mm, sometimes is called speaker wire or lamp wire.
Anyone has trouble connecting here? I get connected ok from any pc then if I log in then after few minutes the access to the site is locked, actually DNS is not resolving it.If I change the external IP then I can connect again and if I stay like a guest I can browse here unlimited.This time I have been on few minutes... still works.It is the same from home also the same when I login from work, different pc's different provider. Any other website if OK.The other day I had trouble connecting to peswiki.com but I think that day they had a problem there.Maybe one of the admins here has set a ban for me???
No I'm sure the owner of this board (hartiberlin) is very happy you are here and I really doubt any other admins would do that.  More likely a glitch in the network or I suppose if some of the PTB types that hang around here were thinking you are finding something too important they might try messing with you.  But I really doubt that too at this time.  Most likely just a hickup in Cyberspace   :)
xenomorphlabs
@Bolt: Many thanks for the answer.
I will just experiment with it and see what happens. In the long run, the perspective to simply drag the amps out of the air is most pleasing of course. For now the earth grounds will have to do.
e2matrix
Preva, I'm not sure where you are seeing ferrite rings in woopy's pics.  I only see windings on top of some other windings.  However based on all the other replications I've seen in pics it does seem ferrite is often used and I have read that it is a good idea which will give more power.
woopy
Hi romero many thanks for advice .
to be sure that i understand you right i made the 3 test proposal. The first as inthe photo = no cap at all. than try to connect a MO cap (1 microF 2100 volts ) as discribed in test 2, and than try other HV cap how much voltage and where can i find them .?
What is good when i make these drawings is that i noticed that i have made a mistake in my circuitery. No it is corrected as pix 2.
@broli
no ferrite only a pipe of PVC 50 mm
@bolt
hehe i have to wait because strong raining in moment, But in fact i am shaking in my trousers
@preva
what you see in the pipe is not a ferrite , it is a caoutchouc ring to hold the center wire in the center of the pvc pipe. Sorry for confusing
@vrand
my ground is very good. and with all this rain no problem.
@all
thanks
and now installation of the lamps
good luck
Laurent
