0 Members and 159 Guests are viewing this topic.
Meta
Quote from: Meta on March 27, 2016, 10:17:51 PM
The Morin video shows nothing at all....are you insane? Where is the free part? Am I taking to robots here? What the fuck kind of idiotic answer is that. The fucking set up produced 6 times more watts than it uses...what the fuck is that? When was the last time you produced 6 times more energy than your machine uses?
You even imagine he is charging capacitors. There are no capacitors.
Void
Quote from: Meta on March 27, 2016, 09:29:34 PM
I was watching a video by Morin sometime ago, and he stopped his small motor in his circuit and played the registration tones the motor made, when turned on.....it was a distinct 4-tones...he repeated it several times and the motor was hooked up to nothing other than the washing machine generator coils he had built....thats how I saw that there was no AC making those tones, because he was coming off a DC battery pack. What made the motor produce the registration tones? Morin says, RF, which he says, acts exactly like AC, what do you say?
@Meta: Crikey mate. :) Those types of little hobby motor controllers are specially programmed to play that little musical
ditty on the motor by sending the waveforms for the those audio tones to the electric motor windings when the motor controller
starts up. Not sure exactly what is vibrating to sound the audio tones in the motor, but that is done intentionally by the
motor controller manufacturer. There is nothing unusual about it in any way. :)
By the way, AC just means alternating current. AC waveforms can be of various types from simple sinewaves and squarewaves to much
more complex waveforms. It is considered an AC waveform as long as the current is alternating in direction. You can have AC
waveforms at a wide range of frequencies, not just in the radio frequency (RF) range.
RF stands for radio frequency, and this is a term used to describe a range of frequencies. The term radio Frequency (RF) does
not contain restrictions to any particular type of waveform or waveform shape. It just denotes a range of frequencies. For example,
you could have a pulsating DC waveform at a frequency that is in the radio frequency range.
So, as you can see, to say that 'AC is RF' doesn't really make any sense. 'RF' does not denote a type of waveform. It denotes
a frequency range only. An AC waveform of some type could certainly be in the RF frequency range, but AC waveforms could also
be at other frequencies outside of the RF range. The 50 Hz/60 Hz mains frequency is below the RF frequency range, as it is
typically defined, for example. Mr Morin has said various other things as well which make it very obvious he has no idea what
he is talking about. At any rate the topic here is about Kapanadze devices and related. So I will leave it at that. :)
NickZ
  Well, Meta. I must be insane, then.  Or you are seeing something that I'm not.
   I'll leave you to it...
verpies
Quote from: Void on March 27, 2016, 12:55:55 PM
The difference between the flakes and the people who are at least potentially authentic is the potentially authentic
people can actually show something that stands up to at least some basic inspection. The trolls and flakes just babble
on with all kinds of nonsense but can't show anything that would stand up to any scrutiny at all. That is really what it
boils down to in a nutshell.
I think there is another name for loose-mind babble, namely - esoterics.
Also, all the authentic people I know, can use a soldering iron.
verpies
The fucking set up produced 6 times more watts than it uses...what the fuck is that? When was the last time you produced 6 times more energy than your machine use?
Watts are not units of energy.  A surprising mistake after 40-years of studying.
It is possible to have 1000x more output Watts than input Watts, by slowly charging a battery and discharging it quickly.
