0 Members and 211 Guests are viewing this topic.
vrand
Quote from: e2matrix on June 15, 2010, 01:08:26 PM
Preva, I'm not sure where you are seeing ferrite rings in woopy's A.  I only see windings on top of some other windings.  However based on all the other replications I've seen in pics it does seem ferrite is often used and I have read that it is a good idea which will give more power.
The photo of the coil end view shows what looks like ring ferrite (dark grey ring).   It looks like it could easly be taken out if needed, if the testing experiments does not reproduce similar to romerouks or JLN outputs.
PS never mind.   ;D
Thanks woopy for the clarification  :)
romerouk
Quote from: Preva on June 15, 2010, 12:50:36 PM
You said that application of ferrite is not necessary! At in a photo woopy ferrite rings are obviously visible. And you say for woopy that it is good work! Specify it is necessary to use ferrite rings or not? If "YES", that it gives?
Thanks.
looking at it a taught that is a rubber to keep the wires in the middle.Don't need ferrite rings
romerouk
@woopy
looking at your drawings I don't see the second earth connection.
woopy
romero
yes i didn't put the second earth ground on the drawings for sake of simplicity.
here under the drawings completed. Sorry for confusing
just for info at about what distance in meter of the house there is no interference problem
do you think ?
@all
there is no ferrite at all in my set up.
Laurent
romerouk
@woopy
In my case I have about 12 meters from the place I do the testing in the garden to the TV, and I can still see lines on the screen but if I cover the spark gap with a box covered in aluminium foil then it is reduced almost completely.
