0 Members and 139 Guests are viewing this topic.
Meta
Quote from: verpies on March 29, 2016, 07:47:57 PM
On an esoteric level that even sounds correct but it lacks a rigorous analysis.
I know a lot about it but I do not know precisely how to manipulate it.  Do you?
Do I know how time is manipulated? Yes I do but metaphysical discussion of it is not for you. Stick with your Physics.
verpies
Quote from: Zeitmaschine on March 29, 2016, 08:25:35 PM
Like a three-phase transformer, where the primary and the secondary coils in use are located on two different legs? Would that imperfect and crappy enough?
Yes, anytime a transformer winding does not span the entire core or anytime air gaps are present in the core - a leakage inductance appears, which becomes capable of resonating with external capacitances.
If you like the Stepanov device, you should investigate ferroresonance in 3-ph transformers (delta connected), because it is not the same as the lumped LC resonance and is considered to be a very wrong thing to do to a power transformer ...and remains somewhat of a mystery.
Meta
____________________________________________________________
My consciousness provided the rigorous analysis even before I repeated it, years ago.
You will have to do the same before you repeat it.
stivep
Format of expression:
Each argument itself  in text below is also just an expression.  look at it as a mark used to indicate stress ,
Pointing at  particular problem without intentional  labeling  you Meta  or a particular group  of  individuals ,as THE PROBLEM in a system  or in a group.
It is just indication of what I think is wrong.
that is all...
Meta.
I'm tired.
Frickin' nonsense, flooding this forum over and over again.
Please understand.
Nobody is interested with your convoluted, estranged,  alienated, and rejected  "science".
I personally have nothing against you.
I do not even  deny your "science"
The problem is that you  are not offering any  complex solution  other than  a "pollution."
Physics is largely concerned as an analysis of motion,
For that there is need for set of tools that are  unified, correlated  and served as logical standards.
There is no problem in classical  and quantum field to work around any problem.
Nobody say it is right  set of methods,  or  there are no  improper standards.
You postulating  rapid change,  and you not offering any complex solution.
You know how it sounds ?
Lets  have some  action :
- Lets jerkoff  .............jerkoff in her mouth  she is an  alien.
does she have mouth?
- I do not know
where is she?
-I do not know?
does she exist?
- I hope so
How did you find out about her?
- From Meta.
a........ OK..
Meta again please give me something solid for my mental masturbation  if you will.......
Will you?
Wesley
Meta
You're on the right trail......heres a hint
The vacuum is balanced, neutralized dynamics (0 dynamics) and perfectly symmetric until you learn about all the ways to asymmetrically unbalance it to produce power.
