0 Members and 337 Guests are viewing this topic.
vrand
[A author=romerouk link=topic=7679.msg245208#msg245208 date=1276626394]
@woopy
In my case I have about 12 meters from the place I do the testing in the garden to the TV, and I can still see lines on the screen but if I cover the spark gap with a box covered in aluminium foil then it is reduced almost completely.
[/quote]
A small Faraday cage, good idea  ;D
flathunter
Good idea from stefan with different spark gap materials....i'll try with carbon/iron/graphite on Friday with my ''scotch and blu tack'' kapagen.  I'll also have family obligations till then.  I'm still really pleased with my shoddy kapagens performance - got the spark gap real small and quiet, and powering all my CFLs without flickering.  Usually i need my TCoil and mains supply but this little beauty does it with a 12V battery....
Yeah, and really need to test my amp input  :D  Should have done that on the first go really!
Great build woppy - you all put me to shame with your professionalism!  Looking forward to results!
woopy
@flathunder
i really have to thank you for your input
you have to realise that with your input, you simply convince me that with very little mean , everyone can replicate the Kapagen or try to do it.
I am  far from beeing a pro, but i simply look at all what is at dispopsal on this forum , jl naudin pix and video than romero the hero, than always impressive work Ossie Callanan  and of course all other contributor
Just for every one who think that this set up is expensive
what you need to replicate is  amasing of simplicity and really cheap and easy to get
20 meters of 3mm2 stranded copper with insulation . i mean that the outer diameter of the finished  wire is almost 4.3 mm2 with the palstic insulation. and it cost less than 1 euro per meter. i used totally 20 meter.  = 20 euros for the coil 1 and 2 plus the main center main wire,
than for the big coil i paid 2 euros per meter and i used 1.5 meter = 3 euros
than a water  PVC pipe of 50 mm diameter 3 euro
and perhaps 5 euros of small parts.
than you go to any garbage of your town and you can get  GRATIS as of many as you can store of MO in which you can find all what you need -
so you see all this is really easy to replicate
but now what is very important is that we go on     and why not           try to approach what everybody  is seeking is                 i mean            the LOOP
good night at all
Laurent
aether22
Quote[ author=starcruiser link=topic=7679.msg245188#msg245188 date=1276619831]
FLUX SOURCE..... MAGNET?????
Not static flux, time varying flux, I very much doubt a plain non moving magnet would work.
Now a pulsed electromagnet should/could work, you want high flux for lots of power.
The power if I am right comes from the fact that an air core coil has to pass a great amount of current to equal the flux a ferrite core can create.
e2matrix, This is why ferrite boosts power, you need to create a stronger inductive field to draw from for a higher output.
Motors, buzzers, transformers, chokes etc...
You do need some flux leakage though, that is why Adams and Bedini type motors with an open magnetic circuit are more suited, and why I think others have noted that with motor/gen setups using normal motors you get better results by drilling holes in the metal shielding around the motor.
Of course a MOT has a great deal more flux leakage than and NST and this might account for that.
bolt
Wonder if Woopy popped out in the back yard to try it yet? If he don't come back soon then have to assume he has vaporised himself and all his wife will find in the morning is a smoldering pair of sneakers:)
