0 Members and 510 Guests are viewing this topic.
v8karlo
It looks like Kapanadze was looking at this topic (Tesla ignition patent)
when he was writing his patent.
Maybe he was looking around this Tesla's patent? It is just a thought. It can be nothing also.
I was wondering on this page when I saw that jpegs:
https://www.google.hr/search?q=tesla+ignition+patent&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiiu7Xdx_XUAhXJsxQKHYWaBVMQsAQIKA&biw=1152&bih=555
v8karlo
It is strange how capacitor is wired on one side to low voltage high current and
other side via inductor (high voltage spikes??).
Recently I was looking at:
Topic: what happens between a teslacoil the battery the incadescent bulb and the ground
What will happen if instead bulb you put capacitor that way.
One leg on accumulator and other on ground wire like in  that
experiment? Low voltage high current on one side and ground
wire on the other side when it is in field of Tesla coil?
Anyway, regards to everyone!
v8karlo
Points. As a points of distribution Kapanadze said in his patent.
Look at the distributor from this picture.
The picture is from the same source:
https://energy-tesla.com/ed-gray-by-mckay-page-1/
What if we place capacitor instead spark plug. A big one.
spark on one leg, ground on other and all of that put in high
density field of Tesla coil. Kapanadze did something like that.
Charging lots of capacitors very fast and strong in a mix of circumstances.
Because,, lots of amps at output of his device can be only from lots of
capacitors which he rapidly charges somehow.
This topic shows very interesting effect which can be related to Kapanadze effect:
Re: what happens between a teslacoil the battery the incadescent bulb and the ground
He is using bulbs, but maybe, only if??? Capacitors!
Field of Tesla coil can be Ingridient in process!
Can be! worth to try!
I talk to much, I know!
v8karlo
Kapanadze coil is decoration only.
The real thing is his resonator, distributor, points...
Which we never saw.
Lots of capacitor can be easily hidden in a small box.
And in every of his movies some boxes are present at
the beginning of the every devices he made.
We always see the coil. Because he want us to see only the coil and
he want us to go in wrong direction and everybody else along with us.
His magnifier is before the coil!
I talk too much again!
