0 Members and 477 Guests are viewing this topic.
Sergh
1. I have a Geiger counter. He probably fixes a muon getting into it once a minute on 1 square  centimeter of Earth.
2. I am familiar with the registration circuit in the Geiger counter and I understand that the energy of this hit is negligible.
3. I know that if you multiply 1 square centimeter by the number of square centimeters in 10 square kilometers, then there will probably be a certain amount of energy from the muons.
4. Everyone knows that the magnetic field from the magnet decreases in proportion to the square of the distance. Therefore, the Kapanadze coil has no chance of affecting an area of ​​10 square kilometers or a distance of 10 kilometers with its magnetic field.
5. The technology similar to HAARP probably allows moving charged particles. But the scale and implementation of this technology are very different from the Kapanadze coil.
What do you propose to do in this situation?
The "keys" to the "locks" are not suitable. This is problem.
Sergh,
I think you like it to make simple thinking complicated :
Question : dimension- difference
St. Bernhard - Massiv Neutrino detector/
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20181113&CC=DE&NR=202018004708U1&KC=U1#
1 Gr.( in mols)  element molecular energy / nuclear energy;  decay duration/ lifetime, velocity
1 cube-cm active-carbon : pore surface in sqm
Water 1 liter to water-gas to droplets : surface in sqm ?  sonolumniscence, charge cluster, St. Elmo,  .....
Thinking in Fermi- Dimension : Fermi-RAUM-ZEIT
A SIMPLE HEATER...  :
electricity to heat
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=102014018647&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
                                        [0003] read, think, design it 3/4 d
and heat to electricity
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=14&ND=3&adjacent=true&locale=en_EP&FT=D&date=19910228&CC=DD&NR=287597A5&KC=A5# Such low temperature decrease gives 80 W( a 400V)  x ?  sqm heat converter surface  ?
( is the circuit in this converter non an argument to nominate Dr. Helmut Reichelt for the Nobel- Award in Physics? An electro-dynamic Carnot circuit, THz modulation )
which quantum mechanical process  ? included inrush voltage/amperage :
            hygrometric/ barometric/ thermometric change
In use carbon-nano-tubes or graphit : as array  with "Funkenstrecke"( TELEFUNKEN)/Funken-Aether
                                                          Funken= spark
" inrush voltage/current limiter" are known,  not in geral use : inrush power converter
wet ambient charge converter :            http://www.rexresearch.com/marks/marks.htm
the article " Electricity from Water & Air " gives probably # 22777 question the answer. !
With appropriate tuning. !
Clouds stimulated by windgenerators to clouds transformed to electricity by "air charge converter"
https://ruhrkultour.de/wp-content/uploads/2016/10/Wirbelschleppen.jpg
ambiental/ health concern : https://en.m.wikipedia.org/wiki/Ionizing_radiation
WhatIsIt
Quote from: lancaIV on May 29, 2019, 03:13:04 AM
WhatIsIt,
slowly !
Dr.Paiva: Voltage Amplifier by ?
Zielinski: Ampere Amplifier by Ampere- turns ratio
We do not need 760 KW nor 990 KW converter, 1/1000 up to 1/100 is for the private household more than enough.
   1/1000 Dr. Paiva example II  760 W x 24 h x 365 d.= 6.657,6 KWh
Compared with 30 sqm solar-cells a 15% efficiency and 1400 KWh photon emission per annum/sqm : 6300 KWh
For such a periodic solar energy converting Installation you have to pay actually +/- 6000 US$, not included
battery system.
I expect that for 1/1000 to 1/100 Paiva/Zielinski/Kapanadze converter at the beginning  the 250 US$/ KW can become easily reached ( calculating with the in the descriptions used materials and  industrial market prices )
I am lost in your talk!
Do you have any plan, suggestion, how to start, make any of that devices?
Because I read their patents and to be honest, did not understand what to do?
Do you know what they are talking about? And how to make them?
If you do, I am in!
WhatIsIt,
where ( later : what) concretly transforms  in the
Paiva device : 110V to 40000 V
and
Zielinski device : 1 A to 5000 A
Sergh
Quote from: lancaIV on May 29, 2019, 05:35:41 AM
This neutrino detector is capable of detecting anything, but not a neutrino.
Neutrinos can pass through the planet without interaction. Neutrinos are detected by highly sensitive photomultipliers of light flashes, in clear water. In large volumes of water, some neutrinos still collide with atoms, but this rarely happens.
http://www.jinr.ru/posts/video-the-baikal-gvd-project/
