WhatIsIt
Quote from: lancaIV on May 29, 2019, 09:43:02 AM
WhatIsIt,
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19941018&CC=US&NR=5356484A&KC=A#
6 microwatt input signal to 2,4 milliwatt amplified output by same signal-to-noise ratio
                      400 x amplification factor
Scientifical acceptable?  Yes and EP- patent granted 26.03.1998
https://register.epo.org/application?number=EP93908635&tab=main
This  as heat-to-electric array with 1 KW electric output and this delivering to the same converter which works as  heat pump ( C.O.P. 10. x) or as refrigerator/ chiller/ cooler
It exists enough accepted ( scientifical and technical) solutions for the future,but the industry works slow : f.e. 1998 to 2019 are more than 20 years sleeping
Now Yater device as same Kapanadze,Zielinski are " open source" :
no company will ever invest in that free technology
8) Let us hope that Dr.Paivas device becomes granted ! ;) Sometimes I think " trojanic"
I looked at patent.
It said Quantum Well Diode?
Tried to google it. Nothing there.
I believe in what you saying.  Nothing of value is open source yet, neither Kapanadze is!
And what is open source is so much complicated that very little individuals can reproduce it. And at the end of that hard work, will it function?
I am more for Kapanadze style. Few wires and simple secret which will come out sooner or later.
But anyway, thanks for the info and effort.
Cheers!
It is less complicated as  it seems - by words " quantum well"  diode  - for quantum well is also in use the prae- fix " nano-" :  https://en.m.wikipedia.org/wiki/Quantum_tunnelling
Quote from: lancaIV on May 29, 2019, 03:25:29 AM
Sergh,
I can imagine it like a "virtual kone" and the receiver like the telescopic installation in Costa Rica !
Following the application description.
I can agree to most of your arguments,but some which can be seen as negative related to the concept are the hidden solutions.
It is a conflict : to tell scientific that there is a source which can be explored, by a huge installation and by the other side to give a demonstration with a small device and useable output : related to average consumer.
Have to correct : not Costa Rica but Puerto Rico the telescope meaning
https://en.m.wikipedia.org/wiki/Arecibo_Observatory
                               Beyond Ferro- magnetism
By classical chemistry non magnetic elements becoming magnetic : carbon/grafit/graphene and http://www.rexresearch.com/mrmagnet/mrmagnet.htm
WhatIsIt
Quote from: lancaIV on May 29, 2019, 11:30:48 AM
Ok!
But, how to do it? Do you have any proposal where to start?
How to make one of those Quantum Well Diode?
I am fairly beginner in this area, but I am ready to listen if it is something which can be made with moderate financial needs.
Can we do it with ordinary parts? Or must we make some special ones?
What is on your mind?
You must have some idea when you propose that.
What is your opinion? Is it doable?
AlienGrey
Quote from: WhatIsIt on May 29, 2019, 07:52:29 PM
Ok!
So what might I ask is a Well Diode (sounds like a British copper saying) well' well' well and what have we got here ? Bozo says sounds like 3 holes in the ground  ;D ;D
so what is it suppose to do?
