0 Members and 80 Guests are viewing this topic.
a.king21
Quote from: WhatIsIt on June 10, 2019, 10:34:00 PM
Kapanadze is history, but his devices are not. They are still impressive machines!
Anyone have some proposal about his devices?
Read his two patents.
WhatIsIt
Quote from: a.king21 on June 10, 2019, 10:45:13 PM
I did. There is difference in schematics!
Capacitor (2) becomes motherboard (4). There is no connection between coils any more.
Nr. 2 is weird capacitor anyway? With 3 leads (or 2 capacitors in some connection?)
Can you point on differences in patent text, so I can connect the dots?
What is he hiding with second patent?
Thanks!
WhatIsIt
I did read both Kapanadze patents and did compare it.
In first I found something interesting.
In this part he is referring to phase and neutral output.
(11). The user uses the electric energy generated in the device by the help of exit (phase) (positive) (12) and exit (neutral) cable (13).
In next part he is referring to feedback. Positive and negative. (How can be positive or negative if output is phase? And not use diode bridge.)
But he is not referring to feedback.
He calls it transformation cable. By mistake he describes process and not feedback. And he place it exactly where it should be, at the end of secondary coil. His output is pulsed DC. And transformation cables are there for polarization from source.
With every pulse he is making copy of output which returns to source.
He said that Melnichenko was close with his copying of field, well, Kapanadze is copying output, but not trough field.
The positive transformation cable (12a) at the exit of the device and the negative transformation cable (13 a) are connected to the power switch. 1-2 seconds after the device starts to generate electric, the electric energy generated is transmitted to the power switch (1) via positive transformation cable (12a) and negative transformation cable (13a).
Thanks A.King, you helped!
Sergh
News from Tbilisi, Georgia (GE), Kapanadze Land:
https://www.linkedin.com/pulse/highly-effective-hydrogen-h2-generator-giorgi-tsivtsivadze
Quote... Cavitation Electrolyzer, Purifier - Hydrogen (H2) Generator.
Power consumption - 1.3 kW / h
Production capacity - 1.5 kg / h of hydrogen (H2) ...
(1.5 kg / h of hydrogen, passing through 60% efficiency Fuel Cell generates 30 kW/h electricity)...Really we have a new method of hydrogen production device, which by its main characteristics is cavitation physical-chemical reactor - electrolysis cell. We developed absolutely new approach for electrolysis: cavitation electrolysis method. Our approach is based on the investigation, fundamental properties of water, investigation of hydrogen bonding in water and its effects on water properties, investigation of cavitation effects on water fundamental properties and its usage of electrolysis. Our approach is completely different from nowadays main direction of investigation for electrolysis.
In given device is developed a completely new cheap hydrogen technology by cavitation electrolysis method. obtained by this technology electrolyzer will be 10 times cheaper of existed prototypes. This technology is also adopted a very significant reduction in energy consumption compared to existing prototypes energy characteristics.
Really we have a new method of hydrogen production device, which by its main characteristics is cavitation physical-chemical reactor - electrolysis cell. Developed absolutely new approach for electrolysis: cavitation electrolysis method.
The device does not require distilled water and working on the ocean water. As for sea water, it could also be used as a device in its own frequency regulation in the water. Also considered to be a side-product utilization in the process of electrolysis.
This generator looks similar to the Kapanadze generator from these videos:
https://www.youtube.com/watch?v=RGizUoKrfGo
https://www.youtube.com/watch?v=XisrBgfX4UY
Frost++
The original ferrite model ОС90.38ПЦ12 used in the Lithuania Experiment up for sale on ebay, please follow the link https://www.ebay.com/itm/363042386643
This ferrite was very rare to find, i was able to get 2 of them and i will be selling only one to another researcher
If your new to overunity follow this youtube link to see expirement https://www.youtube.com/watch?v=gbeseiPPCeM&t=1313s
