0 Members and 262 Guests are viewing this topic.
worldcup
@itsu
Hello,
Yes. i had seen this video before and i'm pretty sure it's the gas geyser HV module
https://www.alibaba.com/product-detail/Gas-Water-Heater-Battery-Electric-Ignition_1600203981227.html
with some mod, on opposite side there seems 3 transistors attached .. i attached an photo from one of his video, is it!
Yes, Some RU might shed some more light on this
@pix
Hello,
Do you or anyone has the components values from the 1st paper drawn schematic ?
worldcup
What bunk says
QuoteThe bunk effect will only occur when the coil is running at 2 stasis frequencies 1/4 and 1/2.
To achieve this, you need to be able to apply amplitude
modulation (AM) to your input signal that goes into
the primary winding of the Tesla coil.
I do it with FY6900 function generator,
which has built-in AM modulation.
Then I set the function generator to amplitude
modulation and used the VCO IN port as the source
modulation.
Finally, I run the output of the signal generator through the amplifier
20W FYA2050S to have enough power for
generation
You are now officially one of the cool kids! 4 4
worldcup
Got this from digging bunch of posts ...
check previously posted image, the black box had heatsink with 3 transistors, in this below image we see transistors removed and are attached on black box from that PCB with same heatsink..
Forum post: https://energyscience.ru/post36129.html#p36129
HD image https://energyscience.ru/download/file.php?id=16932&mode=view
now what's that PCB?
Bunk quotes
Quotea pulse generator from 20-56 microseconds.
worldcup
One video from many of his "All-in one" for above pipe and black box, many videos, with induction load ,such as heating rod,etc on his channel
https://www.youtube.com/watch?v=BmyOjsjzHi8
pix
One step further to explain Bunk setup.
It reminds EH antenna.
Two aluminium foil cylinders separated on the tube.
EH antenna is superb because it is moving far field zone to the antenna, that means current and voltage is in phase. It receives/transmits real power straight from the antenna surface.
And physical size of that EH-dipole is 1% of wave length, that means small antenna can receive long waves.
