0 Members and 158 Guests are viewing this topic.
Sergh
Quote from: pix on May 11, 2023, 10:17:20 AM
1. Water content in hydraulic systems has to be kept minimum. Water breaks lubrication film and wears precise metallic parts of pumps and motors.
But oil experts write that up to 2 grams of water per kilogram of lubrication oil is normal.
https://en.oelcheck.com/wiki/water-content-oils-and-fats/
Quote from: pix on May 11, 2023, 10:17:20 AM2.In refrigeration systems are used special dessicant filters to remove any moisture. Any system that has been opened has to be purged by nitrogen and kept under vacuum pump for several hours to completely remove any moisture. Moisture will form ice and block expansion devices.
Molecular sieve "filters" are used in refrigeration to dehydrate lubrication oil and gas. Molecular sieve, it is also aluminosilicates, it is also zeolites. Molecular sieve filters contain synthetic zeolite in the form of granules. Zeolite nanocrystals are glued into granules with a binder. If you separate zeolite crystals, you get a powder. The powder is slippery, similar to talcum powder.
https://patents.google.com/patent/EP2694631A1/en
Quote from: pix on May 11, 2023, 10:17:20 AM3. Molybdenium is additive oil compound sometimes used in heavy loaded gears to reduce friction in situation when oil film could be broken under peak loads.
https://www.sciencedirect.com/science/article/pii/S101836391600012X
Load (kg)    Coefficient of friction       Coefficient of friction
/force (N)    (engine oil)                    (engine oil
                                                     + 0.3% wt TiO2 nanoparticles)
4/39.226 N    0.111                         0.015
5/49.033 N    0.123                         0.027
6/58.839 N    0.142                         0.093
https://www.amazon.de/-/en/1092-Low-Viscosity-Engine-Molybdenum-Disulphide/dp/B003FMGSOC
:o ;D
https://www.youtube.com/watch?v=oYeI6lYEgyk
ovun987
Quote from: Fabon on July 05, 2023, 02:55:04 PM
My experience  last month, June 3:
https://www.mediafire.com/file/e2rbs52o06jf5t8/Кофе+с+комарами.mp4/file
Cool video, Bunk. The forest there looks beautiful.
In this setup, how much power input? How much power output?
What lengths of wire are you using in this video?
Thank you for sharing.
Your previous posts make it seem as you are not interested in sharing details. Are you interested in discussing specifics specifications of your apparatus?
Fabon
Quote from: ovun987 on July 05, 2023, 03:06:32 PM
I will post here my other video where you can see the installation
** 430 milliamps from battery
