0 Members and 96 Guests are viewing this topic.
Fabon
Very smart guy, and he amused me well with his advanced post!
Now, I answer - too, but I will upload another video!(about this theme)
https://www.youtube.com/watch?v=dy7IaPw5680  ::)
pix
Guys.
You let a fox into a chicken cage.
I am the one that smelled the fox since his first posts on this horum as "Fabon" , because I went through his activity on russian forums and got his style.
Now he is doing here exactly the same he did on russian sites.
Bunk is a con man looking for attention.
1.He did used  other guy russian patent (RU2771054C1 Samsonov Vladimir Dimitrievich)
I guess to gain some credibility, but his "device"  is not even close to what's is in the patent.
2.He lied about his real name.
3.Every one of his movies presenting "working device" is fishy and in every one I can tell where may be a trick with supply wires. There is no one movie I can put my arms down and say  is legit and clearly showing there are no hidden wires.
3. Now Bunk aka Fabon is jumping from idea to idea , and all of them are completely not related to device he is showing.
Don't let this guy play with you.
Cheers,
Pix
Fabon
Quote from: pix on July 07, 2023, 07:07:18 AM
Guys.
Cheers,
Pix
I praise you, quite a worthy statement!
And what do you need to do - the next step!??
Yours is a worthy suggestion for all users....
You can only be judged about me subjectively
because no one knows me personally.
Where I lie, or where I tell the truth, there can only be purely subjective opinions
Subjective opinion does not reflect reality
These are just your superficial fantasies about my person.
Regards!
stivep
Quote from: Fabon on July 07, 2023, 04:36:32 AM
Americium 241 + thorium oxides(ThO2)(White powder)
Thorium oxide in powder form is dangerous primarily because its dust enters the lungs, and can lead to lung cancer in a few years (for which one speck is enough)
Therefore, a protective mask and good goggles are required!...
Information is always in a single words so read carefully:
Data that comes from former inmate, unfortunately  is at institution level he come from.
Some analysis:
1: The band gap of thoria is about 6  = (]1.6 10−19 J) x 6 level compatible to few bananas.
The electronvolt corresponds to a unit of mass It is common in size particle physics, where units of mass and energy are often interchanged, to express mass in units of eV/c2
So you need plenty of mass in kG there to give you  constant 6V  but in  a vacuum and the distance of 2.5 cm=1inch.(don't forget inverse square law) and than
you need charge. literature: /Electronvolt ,   /ev-to-volt-calculator  convert/electric/ev-to-volts.html ,
In a simple language :
Thorium dioxide sometime called oxide, must be used as a nuclear reactor fuel in conjunction with fissile isotopes of either uranium or plutonium
in  order to work at all,  and of course  Bunk  we need to mention  neutron bombardment
please read  section of  Nuclear fuels here :
https://en.wikipedia.org/wiki/Thorium_dioxide
_________________________________
Americium 241 - that was used at home smoke detectors ,  I'll cover later  if needed  as I must go now..
Sorry Bunk-   The presented by you Tesla coil  high voltage device  has nothing to do with  isotopes.
Schematic you posted   has neither ,
Patent you mentioned is not under  your name and has  nothing to do with  Radionuclides.
Wesley
Fabon
Dear stivep, I gave myself a strong word! What, under no circumstances will I personally communicate with you!
For this purpose, I left the private topics moderated by you ...
My best wishes to you!
Regards!
