0 Members and 201 Guests are viewing this topic.
r2fpl
Quote from: Sergh on July 12, 2023, 07:23:26 AM
The output winding of the Kapanadze bobbin is not the secondary winding of the transformer, because a transformer 220 volts 50 Hz 5 kilowatts is impossible in such a design. It is absolutely impossible and meaningless in this device, and in other, for example, in Kapanadze's hydraulic devices.But such a bobbin works great as solenoid.
The term "Current Amplifier" was added to Kapanadze's topic by random people. I would not use such a term, as it means another device in electronic circuitry.
It would be more realistic to call this something a "pulse-stimulated AC source" or "magnetically activated AC source".
https://patents.google.com/patent/WO2008103130A1/en?oq=WO2008103130
Energy transformer being improved with this invention, transforms the initial electric energy received from an independent power supply (1, 2, 2A) and comprises the following parts: - First part consists of an accumulator or chargeable battery, or an inverter or network or any other power supply (1, 2 and 2A) to provide the input energy to the system, - Second part consists of power switch (3), frequency generator (4), capacitor (5), first filter (6), and primary coil (7), - Third part consists of secondary coil (8), current amplifier (9), second filter (10), frequency adjuster (11) and phase stabilizer (12) and load (13), and - The cables (14 and 15) which connect the output (13) on the secondary side to the power switch (3).
stivep
Quote from: Fabon on July 12, 2023, 08:43:17 AM
Bye-bye!
So maybe you'd like to get the same picture in pure Russian, I can give it to you quickly!.... ;)
Translate it yourself at your pleasure!, and I wash my hands of it.
A script like short translation:
in the picture here : https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/192199/image//
Quotecoil made of  copper tubing with the inside wire covered  with dielectric isolation is
compared to a coaxial cable like RG6 or RG 59 that could be winded  instead of it into a coil.
____________________
in right side of the picture text.
Supposedly Kapanadze  words.
in a script like short translation:
Quote- resonance between first  and second coil is important and that is a secret.
accumulated  charge in a coil acting as a capacitor,  discharges itself by spark gap into  the copper tubing.
A second coil  (the inside wire) - in this bifilar  hardly noticeable on the picture is resonating at 50 to 70kHz,  has more capacitance and connected to the ground.
These coils needs to  be at fixed resonant frequency but  the required wire is little to long and doesn't fit  into that coil former,  so it is left hanging from the both sides of  it.
Note: I assume the text is talking about the copper tubing with the inside wire pointing at very wire  as a part of entire capacitor made from the tubing and the wire.
Note: Capacitor has two plates, so is coaxial wire or tubing and both of its components are the part of resonant circuit in resonance. and  there is no distinction prioritizing any of them.
         So the quoted comment about  increased   capacitance. of a coil resonating  at 50 to 70kHz must be equally  applied to both elements of  that coil .
Note: original text in Russian  was convoluted enough to be  misleading and disinforming, so I brought my script into a piece of valuable addition in this translation .
Wesley
rakarskiy
Quote from: r2fpl on July 12, 2023, 10:04:01 AM
Exactly, better visualize 7 and 8 is actually a transformer and 9 is a current amplifier.
r2fpl
stivep
Thank you rakarskiy and r2fpl - nice call
it would be much much nicer to you if it was  sp2fpl
You would  be in free world now with plenty of money and  opportunities so widely open to you at any time  including no visa  needed for travel to USA.
Wesley
