0 Members and 56 Guests are viewing this topic.
r2fpl
Quote from: Sergh on July 13, 2023, 09:12:48 AM
Kapanadze personally did not mention any current amplifier.
The patent was issued for investors through a patent agent.
"Application filed by Turk, Metin"
A current amplifier is a device that receives a small current at the input, and at the output amplifies the current through the load from an external energy source.
If the owner of the patent goes to court, there are doubts that he will be able to prove that something else was meant by "current amplifier".
Kapanadze's patent is no different from other patents. They are much worse. In fact, such a patent does not guarantee anything. I have the original patents in Turkish but it's 100% the same.
r2fpl
Quote from: rakarskiy on July 13, 2023, 09:26:49 AM
Under the name of the element "Current Amplifier", the one who formed the patent, ingeniously disguised the essence and heart of Kapanadze's converter.
It is most easily shown on the diagram of the welding machine. (vice versa A<=>V)
or maybe a Zacarinin transformer.
r2fpl
The only question is how the Ampere current is generated in a circuit with a load.
We know that to add current to an existing circuit, the voltage must be higher than the first current circuit. Is there another possibility?
rakarskiy
I agree, as a variant of the element of Budyonny's welding machine, the high-voltage transformer can be used for ignition of lamps of neon light. The clever Transformer of Sergey Borisovich Zatsarinin, I think has another principle of action (more interesting). I am just trying to solve this, if in a static electromagnetic generator I am trying to get rid of the capacitive connection of the primary and secondary, then under certain conditions this connection is possible as a good thing.
Also if the sources are connected in series, but the additional source in the off state does not interfere with the operation of the setting source. That's exactly what Budyonny's device does.
My crazy ideas to realize such a thing with an electrostatic induction reactor, also with series or possibly parallel connection. The formula just explains where the current comes from!
r2fpl
Quote from: rakarskiy on July 13, 2023, 09:50:38 AM
This is because V and basically 5kV is higher than the transformer voltage of 220V-380V. If it was lower, what would happen? nothing.
The conclusion here is that you always need to have a higher voltage to add currents? Is there another possibility? I don't know after all.
