0 Members and 133 Guests are viewing this topic.
kolbacict
And I'll a little get in about Kapanadze's mechanical device.
Because this theme wasn't finding.
Maybe this is the principle of operation of his mechanical flywheels ? Still.
There is a paradox between kinetic energy, radius and mass that is still incomprehensible to me.
(утка пендос) :D
Sergh
Interesting patent. Registered for an international company. It is strange that I do not find duplicates issued in other countries.
Kapanadze in GreenBox's video was showing a newspaper with an article that blueprints of some powerful sound device had been stolen from Georgian inventors.
https://patents.google.com/patent/GEP19981004B/
https://www.sakpatenti.gov.ge/en/search_engine/view/1493/1/
hartiberlin
This is not from me, but from another user, that might be Nix and wanted to skip the new user check moderation:
Interesting perspective on Kapanadze device from freeenergyinvention..... no longer available. ..
What Tariel Kapanadze has done is very similar to what we just discussed. Except he has just changed the parameters and engineering a little using resonance to complete the picture. (Resonance is everything in a Tesla system) He has taken a Tesla coil secondary first, wound it on a ferrite tube, and agitated it with a high frequency/high voltage supply (instead of the primary). (This is what the feeble spark gap drives) In the mean time imposing on it a 50hz signal with another coil wrapped around it and then using yet another coil wrapped around it that he has 'tuned' to 220v to drive his loads and then using the grounding in the earth as his 'capacitance'. It's as simple as that. This is why he can loop back to a stepdown transformer from 220v to 24/12v to drive his input and and circuits after the initial start because this is an open system and the primary part of the circuit doesn't 'see' the coil of 220v or its load to drag it down as in ordinary 'closed' systems. He has agitated the ambient background with his secondary high voltage coil and is collecting it (220v) with his primary coil wrapped around the secondary. His frequency coil is wrapped around the secondary and set at 50hz. He gets his amperage because of the earth grounding. Simple.
pix
Quote from: hartiberlin on July 14, 2023, 10:47:19 AM
What do you mean for "tuning to 220v"?
To get 220v out of many thousands HF volts you just need a few turns of thick wire because in stepping down it is "voltages per turn" that matters.
To get 50 Hz in that 220v coil is completely different story, you can't get 50Hz out of kHz just like that.
The only way that comes to my mind is to use some kind of interrupter that switches 220v coli "on-off" 50 times per second . It won't be pure sinus at the output.
Cheers,
Pix
onepower
Thanks for the input and this sounds familiar.
What many FE inventors mentioned was the terms "independent" and "isolation" referring to the concept that the input could "do something" then combine with the output. Steven Marks made this same point countless times. The input is not dissipated as we expect and enters the system, goes through some process then shows up on the output. I believe SM claimed the input wave form was riding on top of the output waveform.
In which case we input one unit of energy, said energy has some effect on something within the system generating another unit of energy, then the input combines with the output producing two units of energy. Thus the problem would seem to be how to move energy through a system having some effect but not allowing the initial energy to dissipate. Which begs the question, why does energy dissipate?, what is the mechanism of dissipation?.
A COP of two is also relevant as most FE inventors claimed this was the gain per cycle. The COP could be higher with feedback or multiple stages but the gain per cycle was generally always two times the input. Which only makes sense if the input is one, the induced output a mirror image of the input as one and both adding for a total output of two.
AC
