0 Members and 133 Guests are viewing this topic.
r2fpl
Quote from: pix on July 14, 2023, 04:16:16 PM
To get 50 Hz in that 220v coil is completely different story, you can't get 50Hz out of kHz just like that.
LF or HF filters can be used if we have e.g. modulation
rakarskiy
I like that you are trying to go back to the original schematics of the pioneers in deciding how it works.  But a transformer is not a generator. No matter how you convert volts - the spiral of that connection will dominate. A transformer has an input voltage that you need to understand how it is formed, 220 volts will be held for circuit conditions when the EMF level drops to the Grid voltage. In order to get more current, you need to convert to current the polce of the electric field. A Tesla transformer is just that, a generator that generates enough electric field to convert to current.
I don't want to copy a device with mains output parameters. I want to simplify the task to the level of a converter for a DC circuit.
I decided to continue my post, it will be updated as we work out the elements. Let's try to solve the problem according to the principle of Budyonny's volt-additive.
https://rakatskiy.blogspot.com/2023/07/the-mystery-of-kapanadze-generator.html
Fabon
Quote from: rakarskiy on July 15, 2023, 03:06:51 AM
That's a wonderful thing to say!
But the great mass of people are not able to understand this simple thing!
- Молодец Сергей! (ты должен меня помнить как - "Швондера"... с H2Ososbb) ;)
For you:  https://www.youtube.com/watch?v=W4EfgWjLSBQ
stivep
Quote from: hartiberlin on July 14, 2023, 10:47:19 AM
This is not from me, but from another user, that might be Nix and wanted to skip the new user check moderation:
Interesting perspective on Kapanadze device from freeenergyinvention..... no longer available. ..
What Tariel Kapanadze has done is very similar to what we just discussed. Except he has just changed the parameters and engineering a little using resonance to complete the picture. (Resonance is everything in a Tesla system) He has taken a Tesla coil secondary first, wound it on a ferrite tube, and agitated it with a high frequency/high voltage supply (instead of the primary). (This is what the feeble spark gap drives) In the mean time imposing on it a 50hz signal with another coil wrapped around it and then using yet another coil wrapped around it that he has 'tuned' to 220v to drive his loads and then using the grounding in the earth as his 'capacitance'. It's as simple as that. This is why he can loop back to a stepdown transformer from 220v to 24/12v to drive his input and and circuits after the initial start because this is an open system and the primary part of the circuit doesn't 'see' the coil of 220v or its load to drag it down as in ordinary 'closed' systems. He has agitated the ambient background with his secondary high voltage coil and is collecting it (220v) with his primary coil wrapped around the secondary. His frequency coil is wrapped around the secondary and set at 50hz. He gets his amperage because of the earth grounding. Simple.
I must agree with, rakarskiy, r2fpl, onepower in  quoted by me text:
Quote from: r2fpl on July 15, 2023, 01:51:43 AM
Quote from: onepower on July 14, 2023, 09:02:35 PM
In which case we input one unit of energy, said energy has some effect on something within the system generating another unit of energy, then the input combines with the output producing two units of energy. Thus the problem would seem to be how to move energy through a system having some effect but not allowing the initial energy to dissipate. Which begs the question, why does energy dissipate?, what is the mechanism of dissipation?.
Sense is opposite of nonsense Stefan.
It is like  making some German farmer  text translated  into bad Chinese retranslated back into German understood by German scientist in physics.
This is my value Stefan you can't find elsewhere for free.
Initial analysis what language the text  belongs to :
The quoted text is translated from Russian using  translator (e,g  word  "agitated", " imposing on" )
Sentence : "Resonance is everything in a Tesla system" - is  either  band translation or amateurish level of a passionate.
Sentence : "has 'tuned' to 220v" You can't tune, you can only adjust voltage, that must first exist  somewhere in any form .
Sentence : "His frequency coil"  there  is no such coil . Coil resonates at given F if energized by induced or delivered AC.
Sentence : "gets his amperage because of the earth grounding"  right word is "Current" and grounding  is part of a circuit.
Sentence : "using resonance to complete the picture"- expression  Yes.. so what? the picture is blurry or to far away or not there.
So  Stefan - The English version of it  is convoluted.  For me it is bad translation.
This text in Russian is  much  more consistent almost alike the original text -  despite of its value:
"То, что сделал Тариэл Капанадзе, очень похоже на то, о чем мы только что говорили.
За исключением того, что он только что изменил параметры и немного спроектировал, используя резонанс,
чтобы "завершить" картинку. Сначала он взял вторичную обмотку катушки Тесла,
намотал ее на ферритовую трубку и взбалтывал ее высоковольтным источником питания (вместо первички)
(Это то, что приводит в движение слабый искровой разрядник)
В то же время он наложил на него сигнал 50 Гц  другой катушкой, обернутой вокруг него,
а затем использовал еще одну катушку, обернутую вокруг него, которую он «настроил» на 220 В для
управления  нагрузкoй, а затем использовал заземление - нo в земле в качестве своей «емкости».
Это так просто.
Это - то, почему он может образовать Самозапиткy - (Запьетлить  назад) к понижающему трансформатору от 220v до 24/12v,
(чтобы вести его вход ) /управлять входом и цепeй после первоначального запуска,
потому что это открытая система, а основная часть схемы не «видит» катушки 220V  и/или ее нагрузки,(xxx)
как в обычных «закрытых» системах."
__________________________________________________
conclusion:
Presentation  of Tariel in the remote  island  near Turkey  could not be explained by  the quoted text.
So my friends fluent in Russian try to make sense form it.
Wesley
Fabon
Atmospheric electricity nanotechnology of the future!
graphene nanoplatlets and nano cellulose powder make a paste that converts water vapor in the air directly to power
More mass creates more electricity. This creates the imbalance and capacitor discharge. UMass Amherst also uses different size electrodes along a moisture gradient
Graphene nanoplatlets. And nanocellulose. You can order them.
Ionisil nanosilicon in it creates even more energy, graphene aerogels with nanopores. high volume. low weight. high air to electricity output. now being made in Russia
I don't post movies on my YouTube channel anymore! but only here...
  :) https://odysee.com/Nanographene+nanocellulose-electricity-from-the-atmosphere:9
