0 Members and 57 Guests are viewing this topic.
rakarskiy
R2FPL, thank you for the information:
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg580265/#msg580265
It was too naive to assume 100% solution of the problem, on Kapanadze generator. I know this patent, and other variants of work with MU-energy. It certainly does not apply to the Kapanadze generator.
The method of obtaining high-voltage potential can be any, which can then be discharged to the corresponding converter. Perhaps I am wrong, but I have put something together in one principle: Kapanadze, Stephen Mark, Sergey Zatsarinin. Let's see what will come out of it.
r2fpl
Quote from: rakarskiy on July 17, 2023, 03:51:35 AM
Steven Mark also talked about these Muons. They basically all talk about energy from the cosmos or the environment.
Steven was convicted of fraud against investors. It was announced on websites on the Internet. Probably Mark is already dead.
His partner Durban Jack said that Steven never told a secret even to him. However, he confirms that he was unable to understand how these devices work, but it is definitely not a scam. although it does not rule it out.
I didn't know anyone had been able to replicate these devices. There were some movies a long time ago, but it's not so sure.
In my opinion, you need to look for similar solutions, such as pumping up the mattress. It's about hypotension. If you have compressed air, when it goes into the hole, it sucks up all the other air around you.
This is a very simple operation and works very well with air. How would it work with electricity?
If the air is replaced with electrostatics that sucks in, for example, free electrons, we would have an anology. In principle, it is similar to the Linde device. Kapanadze mentions that he catches the energy around us.
I see a problem here with the fact that if this were the case, there should be hundreds of kW of energy around us. We remember 100kW Kapanaga. These coils should take everything around to themselves. However, people normally go there. There is no wind or other bad conditions.
If all this energy is sucked from the ground!? same as the method I mentioned at the beginning.
Fabon
 :o  Efficiency greater than one is possible in a so-called "open" system, this is when the input of the device does not "feel" many output loads. We can cite a large number of devices with this effect as an example, but the official physics is trying hard to shrug off these facts. It is not at all favorable to the circumstance that people would not use the services of high-voltage transmission lines, and thus the power companies in general!...
                       (Better a bird in the hand, than a crane in the sky!):
https://www.mediafire.com/file/g5zoirjgl2hm2d4/Open+systems.mp4/file
Sergh
Quote from: r2fpl on July 17, 2023, 04:31:14 AM
QuoteHermann Plauson was an Estonian professor, engineer and inventor. Plauson investigated, among other things, the production of power based on atmospheric electricity.
QuoteAnd now our author gives us some practical details. He says that on the Finland plains he carried out experiments with a balloon made of aluminum leaf with collecting needles of amalgamated zinc with a radium preparation as an ionizer. The surface of the balloon was sprinkled over with zinc amalgam. It was sent up to a height of 300 meters, early 1,000 feet, and was held by a copper-plated steel wire. A constant current of 1.8 amperes at an average of 400 volts potential difference was obtained. This gave nearly three-quarters of a kilowatt, or close to one horsepower. The collector of the balloon insulated from the earth showed a tension of 42,000 volts. By sending up a second balloon with an antenna to the same height at a distance of 100 meters from the first balloon, a current of over 3 amperes was obtained. Then by putting into the circuit a large condenser, whose capacity was equal to the surface capacity of both balloons, and of the antenna connections, the current rose to 6.8 amperes with about 500 volts mean tension. By the use of these two balloons, he eventually ran up the power to 3.4 kilowatts.
https://www.nuenergy.org/power-from-the-air-follow-up/
Big. Expensive. Dangerous. Low efficiency compared to modern wind turbines and solar panels.
rakarskiy
R2FPL
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg580268/#msg580268
Even Faraday did not "got it" how his induction coil, with the help of which he discovered the law of "Electromagnetic induction", works. This position, too, reached me like a "giraffe's head".  Simply I have skills of gathering information and its systematization and analysis.
Today, ask a question: what is the difference between a traditional transformer (in principle, Faraday's induction coil) and the simplest synchronous generator with a core (which was first proposed to Faraday himself, the  imponderable author with the initials [P.M.]) you still will not tell you exactly no one.
I've updated my post: https://rakatskiy.blogspot.com/2023/07/the-mystery-of-kapanadze-generator.html  a very interesting calculation, even though it is an assumption, but still ...
