0 Members and 204 Guests are viewing this topic.
Fabon
 300 watts output, with input = 30 watts,  -\  the author's clever device:
Dog-One
Oleg's box (still running after five hours):
https://www.youtube.com/watch?v=EbVFSm7AhKQ
Notice comment:
"Yes, guys, everything is freely available, only the only thing in the telegram channel write to me, I will give a link there is all the information."
Telegram +380673856845
Enjoy!
dxer_87
Lenin Punk made my day. I always believed that overunity transformer should have three windings and be geometrical outstanding... So that's why I am proposing wounding a coil just on the existing transformer... I don't remember if neutral should be connected better than grounding on so called grabber.
According to topic all I know and had built was always three windings magic coil, two multivibrators, tv flyback coil or other transformer like microwave oven and all can be driven via stereo audio amplifier (dual mono) - this work as amplified multivibrators. Only work is to get it tuned into resonance. The coils which I was wounding was always made without any instruction/other concept. Especially SR193 coil easily resonates. You can tune anything above 50 turns on 40mm plastic pipe. Because the resonance just needs this geometry in space. Once you managed to make coil, You just tune the frequency. PS. Not all electricity goes from the ground. It comes from the resonance (into coil wire), also parts manufactured nowadays in some condition has a little bit OU in it. This can be showed by soldering simply RC circuits or diode-capacitor in series. Even simple voltage divider based on resistors if soldered more than 50 times one after another of lets say 22k and 68k resistors will show You voltage on output if grounded first. Sounds freaky but I've tested this once in 1991.
