0 Members and 141 Guests are viewing this topic.
aether22
Quote from: What_The_Flux on June 16, 2010, 08:49:29 PM
@xeno
That certainly isn't my intent. My focus is to try to reverse engineer Kapanadze's device.
In fact, the point of my comments were meant to try to steer the forum back to his principles, and what little we actually know about the device.
But I may still be ignorant on some of the subtle differences between TK's work and Don Smith's, so I apologize if I've strayed.
Here is what I'm referring to, from the only actual interview I've seen with Kapandze himself (and what I see little discussion on so far):
As gas been pointed out, Kapanadze has had a lot of attention and only 1 or 2 out of tens of thousands have had any success, and the only one that did says resonance is a misdirect, which I would tend to agree.
FE has been achieved by hundreds but there have probably been on average less than one successful replication for every presented FE device, replicating FE is very very fraught with complications and one of them is inventor secrecy and complex devices both of which are present here.
Getting this "back to pure Kapanadze" is chucking away success for a very very longshot, if you want to try it go ahead, but discouraging anyone from replicating a semi reliable replicate-able setup as this is to hold back the movement of FE perhaps deliberately given the apparently purposeful screwing around with RomeroUK's connection.
Better start with solid ground (Kapangen) and reverse engineer it into a normal Kapanadze system.
vrand
@xeno
This is an Open Forum and the Moderator, Pirate said that this thread is open to anything that even relates to Kapanadze.
So thank you for the input and good luck to your design build!   :)
Yes, Kapanadze mentions resonate being the key to his design, both in his videos and in his patents, and our theoretician bolt says that is the way to go. So far no has succeeded in doing it that way AND publish the built details in an open forum. The closest was SR but then he stopped talking, and no one to date has reproduced his design.
So yes, please share your design and test results here!   :)
Thanks, Mike R.
exnihiloest
Quote from: xenomorphlabs on June 16, 2010, 10:02:19 PM
People went into all kinds of bizarre theories of transmutation and nuclear resonance, yet no-one has nailed it down.
To explain what?
Before a new theory, the first point to check is: have we OU? We have no evidence there is OU in Kapanadze device. This needs to make it selfrunning, or at least requires a difficult measurement protocol (due to HF currents) and at my knowledge nobody made it or even tried.
stephenafreter
@vrand
can you indicate the patent number from Kapanadze.
Are they in Engish ?
Thanks
vrand
Quote from: stephenafreter on June 17, 2010, 03:04:02 AM
@vrand
Thanks
Here is one of his patents:
WO2008103129A1
http://www.hvlabs.hu/zpe/Gruz/WO2008103129A1%20(1).pdf
Will post the others when I find them as they are similar, and show no details and are only block diagrams.
