0 Members and 164 Guests are viewing this topic.
callanan
Quote from: baroutologos on June 17, 2010, 09:49:01 AM
Did you saw Naudin updated site?
It includes the replications of Romerouk, Dragon, Woopi, and Retrod as successful replications.
This Naudin situation is getting hillarious. How the success is defined by Naudin? To make a Kapanadze looking setup or OU?
One only has to spend some good time going though JLN's website to see and realize that he doesn't do all of this great work for laughs. His efforts and intentions should be applauded and respected.
hartiberlin
Yes, you can use them, but only in series, so you have 4200 Volts rated voltage breakthrough withstanding.
And then use at least 10 x 1N4007 diodes in series as the high voltage diode
to use this in a DC configuration to charge up these caps.
Be very carefull with these charged caps and solder a bleading discharge resistor of around 1 MegaOhm
across each of them ( Wattage of the bleading resistors must be at least around 20 Watts !)
and don´t touch them.
Hope this helps.
slapper
There could be a second or perhaps a 3rd spark gap. Placing a 2nd spark gap across the large coil may yield some interesting results. Take care.
nap
we are not alone :)
callanan
Enjoy, and please always be careful at your own risk.
callanan
I can confirm that JLN's input power only started to drop dramatically when he added the big steel plate as shown above.
