0 Members and 162 Guests are viewing this topic.
hartiberlin
Hi Ossi,
very interesting, is it your box or the one from Jean Louis ?
Did you visit him  or did he send you these pics ?
How long did this box stand there on the same spot ?
Many thanks.
Paul-R
Quote from: woopy on June 17, 2010, 10:45:09 AM
OK i have found 2 MO caps but oops there are not 0.1uf  but 1 uf (or 0.95 uf) can i use them ?
Don't forget that there is a 1megohm resistor connected across the connectors.
(Often, it lies just under the top cap. In theory, it could be drilled out but expect failures).
Will this matter?
callanan
Quote from: hartiberlin link=topic=7679.msg245475#msg245475 A=1276789070
Hi Ossi,
A did this box stand there on the same spot ?
Many thanks.
Hi Stefan,
Please see the updated circuit now in my previous post. I have been working hard and long at this replication and am still doing so. JLN has been so kind to correspond with me and share these details and has said it is OK to share them with everyone. All of the information in the previous two posts of mine have come from him. I believe we have all of the knowledge now for a successfull replication of his Kapagen design.
"the grass hasn't grow since the 4 june"
"The Kapagen box placed here ONLY during the experiment (used time about 30min) and moved back to my lab after"
IceStorm
What puzzle me a bit is the ground rod. There a simple experiment people can do , place a earth ground as JNL , put some water to make it a little better conductor , put a wire on the Hot main of your house, attach it to the ground rod, there will be about 1.5-3 Amp flowing on this one wire going to your ground rod, don't touch the Rod , there will be 100-300 Watt so it become extremely hot.If you don't get any current flow, you just have the wrong wire, use the other one.
Should look like that:
             Wire
Main(+) ..........|| Earth Ground
Main(-) Not connected anywhere
There a direct coupling between the House ground and the Earth ground proved by this simple experiment.
I don't mean JNL is extracting his energy from the House but its something to take into consideration.
Best Regards,
IceStorm
woopy
Wow Ossie
hehe little secret revealed. Thank's a lot to JL Naudin. I will try it as soon as possible.
Do you think that the steel plate must  be under the MOT, or can we put it on the ground at the distance, and connected with a wire to the MOT basement ? Or perhaps simply plunge a third steel bar in the ground and connect it to the ground ?
thanks alot for input. Hehe as i said perhaps we are succesfull without knowing it !!
@Stefan
Thanks , i have already connected 10  1N5408. But i will first try the PLATE. With AC and no cap to see the difference with my testing of this morning
Laurent
