0 Members and 145 Guests are viewing this topic.
tadejstenta
My coil winding : 22 turns of 1.5 mm wire, 81 turns of 1.5 mm wire and 7 turns of 2,5 mm wire
coil is the same in both tests
first (hundreds of them) test based on first scheme(index.php.jpg) and now based on callanans scheme- only i did not put metal plate under the MOT, just have connect it with one wire from outside which is stack into ground about 2 cm
tadejstenta
The big coil is sitting on PVC spacers about 2-3 mm high
Quote from: tadejstenta on June 17, 2010, 03:22:53 PM
It seems like your circuit also shows the diode hooked considering positive current. I assume you flipped this around as well?
tadejstenta
i did it like it is in callanans scheme ( thanks again for sharing)
before the MOT i have variac and during this short test i noticed, when i lower the input voltage amp draw go up. But for detailed testing  ::) there was no time.
i had so big need to share result  8), and of course not forget to mention callanan - again.
my PVC tube is 50 mm diam., in the tube i have 5 times 3 mm steel or silver coated wire - but in previous tests I had 6 times 1.5 mm cooper wire and i did not noticed difference.
vrand
Quote from: callanan on June 17, 2010, 11:55:37 AM
JLN's spark gap!
Nice "heavy duty" spark gap Jean Louis!   ;D
Is he seeing spark's or arc's?
I would enjoy seeing a video of that spark gap in operation.   ;D
