0 Members and 196 Guests are viewing this topic.
albert
This is why I would like to see WHAT is illuminating  the bulbs. RF? "Radiant" Energy? Or simple 50/60 hz AC? I'd like to see some scope shots or at least a clamp ammeter on the output....with RMS processing.Do the underwater test or use a thin wire and you'll see what is going on...or try a bulb with broken filaments. If it lights up it is ionized - RF energy.
Bruce_TPU
GraffixWB
THis is all pretty amazing stuff. THis appears to produce LOTS of extra energy. I'm sure someone has said it b4, but shouldn't a water temp increase/time test be run? this would take care of any BS debunking about actuall energy in/out and let us get on with educating the population.
P.S. I don't know enough about r.f. r.e yet. Could this be stealing from the power grid? I didn't see anything in the posts about this being proven or disproven.
Ima go to class and then build one this afternoon!!  talk about excited! (im an EE student so I know full well about the dangers of HV ;)
xenomorphlabs
Quote from: GraffixWB on June 18, 2010, 08:07:47 AM
Probably that is because you have not read the whole thread.
And most people don´t even bother to read anything except the newest page, which results in double or triple posts of the same diagram    :D :D
dllabarre
Quote from: xenomorphlabs on June 18, 2010, 09:10:35 AM
and people's questions don't get answered...   :-\
I understand that a fast moving thread is hard to keep up with and people have families, jobs and other responsibilities that take up our time.
