0 Members and 196 Guests are viewing this topic.
woopy
Hi all a lot of testing today
1- same set up as yesterday with spak plug and no cap no diode. This morning it draws more than yesterday (it rained all the night) perhaps the wettness of the floor can influence but it draws 4.6 A. (4,2 yesterday)
2- same set up but i put a third ground line, from the basement of the MOT to different mean of "plating" at about 8 meters distance. exactly in the middle of the 2 main ground . the current draw did not change.
3- i measure the current draw of the comparison bulb which is directly connected to the house grid , it draws  0.41 A that is 0.41 x 220 volt =90.2 watts lets say 90 watts. That is to say that my bank of 10 same bulbs at full brightness needs 900 watts.
4- I installed the cap and diode but keep the spark plug . and the current draw goe down to 3.55 A the brightness is good but flickening, and the RF in the radion is very small. The electrode in the SG did not heat too much.
5. i installed the tunable SG and try all sort of electrode. and tried different opening, the current draw is very different dipending of material. Sometimes the brightness of the bank is much higher than the test bulb.
for instance with the copper electrode the spark is green the current is strong and the light is very high i have feared to fry the bank.
i made a comparison brigtness between the test bulb and the bank of bulb and as you can see they are very similar
6 i tried also  to put a thin soft steel plate under the wooden bord under the mot and connect it to the third ground line but no A decrease.
After sometime testing the MOT temp was 60 degree celsius for the primary and 70 degree for the secondary, When the MOT is hot the A draw is also bigger
OK for today  the best A draw is 3.55 with MOT cold  and the bank brightness identical to the the test bulb  , But no chance yet with the outer third grounding.
And the cap and diode greatly improve everything but be carefull with your finger !!
Any idea or suggestiion for the "plating" ?
regards
Laurent
Quote from: woopy on June 18, 2010, 12:23:18 PM
regards
Laurent
Hats off to you woopy. I would suggest one more additional SG test. Monitoring amp draw with magnetic quenching of spark gap that is if you have a neo magnet laying around.
flathunter
Great work Woppy!!!
Can I confirm that you're using ''woppy B'', i.e both 20ish A and 6 turn currents running against the 80 turn current????  It looks like Naudin is running the 20ish turn WITH the 80 turn, so that the currents are in the same direction.....perhaps this just doesnt matter which way the turns are running for the first 2 smaller diametre coils??
Anyhow, my 26 turn is running in the opposite direction to my 80 turn, and the 6 turn is also opposite to the 80 turn.  Ill have some pictures later tonight of my 12 V battery running some CFLs using the Kapanadze generator......watch this space....
woopy
Hi broli
what do you mean exactly with quenching the SG. I have neo mag so no problem. Can you make a small drawing please.
Now for the winding it seems that JLN made the the coils at 108 turns. So perhaps the left parts of "woopy B" that i use should be inverted.
Perhaps JLN or callanan couid clear that point . Bolt sayd that there is no importance with the direction of the winding. But if we are OK with that, we would be sure to replicate correctly.
So my question . In the drawing her under i have used "WOOPY B winding , so have i to invert the direction of the 22 turn  (red wire) on the left . and wind them as the WOOPY A (red wire)?  yes or not. Thanks
regards
Laurent
Quote from: woopy on June 18, 2010, 02:22:01 PM
Hi broli
regards
Laurent
http://www.youtube.com/watch?v=hwVvHgbJdzA
Around 0:22 you see what I'm talking about. Tesla explained this and the air setup in one if his early lectures. The magnet or air causes the spark to extinguish as soon as it's formed. In the kapa device it might or might not do much.
Edit: This video http://www.youtube.com/watch?v=EtLlAljKQ4g is more relevant as he's using a MOT. First experiment with no voltage doubling cap and diode, second with. By adding the magnet to the spark gap the spark gets much more violent.
