0 Members and 196 Guests are viewing this topic.
flathunter
[A author=tadejstenta link=topic=7679.msg245712#msg245712 date=1276897399]
hartiberlin
- when i had connect the third ground line to MOT i saw no changes, i put MOT directly on the ground - grass and nothing changes, but i noticed, i had to have At east two ground - that is when i disconnect one, system stop
also noticed, when the one of wire to the ground is only in one side connect to system and at another side is just laying in grass than system runs, but amp draw increase
regards,
tadej
[/quote]
Yeah - I also need 2 grounds or my spark gap dont spark.  This is for the NST/mains and the 12V pulsed HV DC.
hartiberlin
Hi tadej and ALL,
how do you measure your input current ?
Just with a digital ampmeter ?
These meters could be jammed easily via the
sparkgap pulses..
I just calculated and it would be beneficial to
put a 50 Watts 12 Volts Halogen bulb in series
with the 230 Volts AC input.
This way you can already see, how much current your system
draws.
Hope this helps.
Well on 120 Volts AC 60 Hz systems better get a 6 Volts 60 Watts
bulbs.
Regards, Stefan.
hartiberlin
Quote from: retrod on June 18, 2010, 06:25:40 PM
"Admin had asked  8. Is it true, that a copper-graphite spark  works best in
or is there any other dissimular metals pair, that will work better ?
Okay, maybe a few experimenter can try to find this all out ?"
Today I tried a combination of gas discharge tubes in place of a spark gap. One of them worked really good, I noticed purple arcing to the unused trigger wire, for whatever reason this enhanced operation over a regular spark gap. I made a video of some of the testing.
http://www.youtube.com/watch?v=sgpIKx9__-4
Hi retrod ,
very interesting !
What kind of gas discharge tube did you use and how did
you turn it on ?
(Most gas discharge tubes need a high voltage pulse to start them up.)
Many thanks.
P.S:Please use a 12 Volts 50 Watts halogen bulb in series with
the 230 Volts Input to see the input current.
Regards, Stefan.
dole
In the meantime of the rain.
Some ours to test again but probably weather was not good for this type of equipment. (Interesting if someone has been observed the same.. or only one ground wire next time :-)
It's started promising but got worse as ground get more wet and destroying dielectric. Anyway there is some effect of ground but I'm not sure how to tune for now. Need more testing.
I was just watching original kappa video, as we know that Kapanadze not connecting lamps as kapagen do, but does anybody have clip from video where cables from lamp are clearly shown?
Thanks to all for hacking this.
d.
So 5x300W
