0 Members and 242 Guests are viewing this topic.
xenomorphlabs
Quote from: jermutin on June 18, 2010, 05:56:37 PM
Hi all,
I'm new in this forum. :)
I have been anxiously following this thread and JLN labs progress. It all just seems to be going forward so well. I've also started to gather some things for my own replication..
But I have to ask about a comment posted right in the beginning of this thread.
And this really set me thinking, that could it be possible, that all those Watts are being robbed (accidentally) from the house grid / other system nearby.
I'm not meaning to be a naysayer, but one has to ask these things.
I would really like to see someone using the Kapagen with a diesel-powered portable PSU in an area where theres no possibility for the power to be coming from another grid..
But, I truly hope that the excess power is being craved from "the wheelwork of the nature"..
-J
Put a little more effort in and read the whole thread.
All the "power-stealing" non-sense has been discussed already.
bolt
Solution as posted now by me many times and repeated by my good friend. Use motor AC RUN caps in series to mains you can calculate exactly how much current can flow thru regardless of what the meter reads.
There remains niggle in some minds that HV pumped into ground can create PD between neutral and house EARTH creating more ground current to flow rather then what is coming in thru live where the meters will show a fake OU reading.
Someone going to have to debunk this soon using batteries and inverter or small genset.
Series cap will also prevent overheating as a "quick fix" but to do this properly requires power factor correction and a second MOT as ballast. Not see anyone use ballast yet even though several
people have stated they have a "few" MOTs laying about. This will HALF i/p current.
a 50uF Run cap in series on one leg of the low volt side of the MOT to regulate the input current to a lower value than what the MOT is capable of passing thru without this series placed run cap inline.   With this cap the input doesn't go over about 4amps-4.5amps on the 120volt 60hz USA mains
Bit hard to find nowdays but at 4kv is enough to use Mercury Vapor lamps as spark gap!
As Don Smith used GDT's looped to void the fuss and noise of spark gaps these GDT's operate silent and flicker free but finding one to handle 4kv at 10 amp peaks is not cheap to replace spark gap.
A 125w "street" mercury vapor will provide perfect spark gap. It also has one very very special property that tesla knew about. Mecury vapor is a high power DIODE! He shows these used in some of his patents. SO now you can have a silent spark AND a diode which is very very hard to destroy in one 10 buck package. Plus you get an additional light for free rather then heating up spark gaps.
IF you get i/p current down to lower levels so you can trust the MOT will not overheat AND you have a silent mercury vapor "spark gap" then and only then is the kapagen making a real energy saving solution where it can actually be left running for more then 5 mins:)
GraffixWB
Hey all.
  I was planning on building a few 2L bottle caps and using them as the HV cap. would any advise against this? I can buy a vacuum cap off ebay but would rather build the circuit TOMORROW :) and not next week. I am just looking for advice from the seasoned experimenters.
THX!
bolt
Quote from: GraffixWB on June 18, 2010, 11:11:13 PM
Hey all.
THX!
Oven caps to double the voltage are about 1uf rated around 9kv and i know some will go to 15kv before they die.
So if you are going to make one using cola bottles you need about 150 bottles to get 1uf at this voltage rating:)
If you cant wait then try it at 2kv only.
dllabarre
-J
I have a portable gas powered generator and I plan to take it to the country where there are no houses, no underground electric wires and no overhead electric wires.  This will prove if power is being robbed from the electric company or coming from "Earth".  First I need to stabilize my build.
Don
