0 Members and 200 Guests are viewing this topic.
woopy
Hi all
Another day of hard testing.
no time to detail everything now
but in resume
i wound the coil as per WOOPY C, the inductance goes from 0.02 mh to 0.076 mh  but no better result with the current draw.
Than i changed the center rod as per JLN nothing better
than i tried a lot bof grounding and antenna. nothing remarkable.
than i shortcuted the SG no big difference,
than i bypassed the complete coil but let the 2 ground and the sg. And big improvement. i could go down to 2.7 A for full brightness (comparison with the terst bulb)
the gap must be very fine tuned to get this results . Will redo all of this .
So my idea is that my coil is not in resonnance at all. and is more a resistance.
than i tried to insert a steel tubing and the inductance can go from 0.076 mh to 0.295 mh, and try moving slowly, but no resonnance.
Any suggestions ?
good evening
Laurent
coke2k
Try to do the following: Use multiple cable lengths for the primary and secondary coils, so if any frequency appears  to be a resonance frequency for your transformer, its good the cable length to match the wavelength. The SG is a real full range generator  and 100% there will be a frequency witch wavelength will match to your cable length. So just use 5 meters cable for primary and 20 meters for secondary coils or revers it. The more long cables  will resonate at more low frequency
Quote from: woopy on June 19, 2010, 12:38:51 PM
Hi all
but in resume
Any suggestions ?
good evening
Laurent
You sure have been busy. Thanks for reporting back. Your inductance test is not very encouraging at first sight, but there's still the possibility that the inductance must increase even higher if possible. Anyway thanks for your work thus far.
romerouk
Today I have built another identical coil with the original one. I have used same wire, same pvc, everything like before.The first attempt showed 2.4 amps for 10x100w bulbs. I have disconnected everything and connected the original one. It shows 1.8 amps... connected back the new coil and the 2.4 amps again.
Two identical coils should behave identical or  at least close enough. The only visible difference is the spacing between the big coil windings as the other spacing for the  long windings are identical.
I have adjusted it and the amp goes higher, 2.8amps. I was not able to adjust the spacing to reduce the amperage down to below 2 amps.At this moment in time I am afraid to even change the smallest thing on the original one thinking that I might not be able to bring it back to this stage. I need to play a bit more with the second coil and see if I can do more adjustments. Many of people here are wondering why J L Naudin and me are reporting low amperage and now I have discovered this big coil spacing. Maybe there are other differences but this is all for now.
I was expecting that some of the replicators will have similar results with me or  J L Naudin and I was wondering myself what is everyone doing wrong? The SG must be also very, very small distance between the rod terminals.
I will do  a video or some pictures next time I will go back to work on it, for now I need some time to relax.
All the best,
RomeroUK
