0 Members and 214 Guests are viewing this topic.
MrWolf
Quote from: xenomorphlabs on June 20, 2010, 08:12:41 AMThat can not be true, the current from the pipe grounding is being measured here.
Good point, maybe I mistranslated or misunderstood. Probably he meant that there is no current in the pipe when device is NOT running. (because he was accused of stealing from power grid via this pipe)
hartiberlin
Quote from: Bruce_TPU on June 20, 2010, 09:26:42 AM
Hello ALL,
I think that the most interesting "take away" from Mr. Wolf's narrative, two posts above, is the following....
BOTH grounds were large and filled with water.  A radiator gives great surface area and holds a large volume of water, and his other ground pipe was also filled with water.  I do not believe that it was by accident.
Using two grounds, with metal surfaces filled with water.  I will not theorize why, but would perhaps show an interesting effect if experimented with.
Cheers,
Bruce
Hi Bruce and ALL,
in the original video, they showed the cooler grill buried in the ground,
but later they used only the waterpipe to ground the circuit and
in the later videos also only ONE groundwire was used.
So it seems to okay, just to use one ground wire.
I guess they just suck out of this good conducting ground
wire the free electrons in resonance.
As the ampereter shows around 22 amps, there you have it.
The Kapanadze circuit must be a High Voltage pulse excited
resonance system for 50 Hz which pumps the 22 amps back and
forth from the ground  to the bulbs via a 50 Hz resonance system.
Otherwise the meter would not work correctly, if there would be
flowing just radio frequency burst pulses in this ground line.
Maybe someone can finally use a pickup coil on a scope
and show us the waveforms, that the Kapagen circuit from
Naudin generates ?
Without using a scope we are just blind with these circuits...
How can we optimize it, if we don´t know the waveforms ?
Many thanks.
Regards, Stefan.
Quote from: hartiberlin on June 20, 2010, 10:53:29 AM
Hi Bruce and ALL,
Naudin generates ?
Many thanks.
Regards, Stefan.
If there is an earth to coil resonance this can be easily found. Imagine the method used to find resonance of mass. What you do is bang some object with a certain force and by using a microphone and some FFT software you will instantly see the main frequency of vibration. Now this same mechanical analogy can be converted to electric. What you do is give the coil a bang from a capacitor charged at different voltages. Then using a dso with FFT function you can see the frequencies the coil and earth ring at. Note the highest peak at certain voltage and start banging at that frequency. All easy in theory  :P .
dllabarre
Quote from: romerouk on June 20, 2010, 09:20:36 AM
I don't have an inductance meter.
I have abandoned this  arrangement as I have discovered  a better one. It was a good inspiration. Now  I use a primary and a secondary coil. Not ready to publish results as I am very busy doing  testing to this new way of utilizing Energy.
I'm only using a primary a secondary also.
Thanks for responding,
Don
znel
Hi Bruce and ALL,
Otherwise the meter would not A correctly, if there would be
Maybe someone can finally use a pickup A on a scope
Naudin generates ?
Many thanks.
Regards, Stefan.
That, of course, assumes the meter is reading correctly.   I've always been taught - never assume anything.  Test and re test, the truth will be come apparant.
