0 Members and 52 Guests are viewing this topic.
Quote from: znel on June 20, 2010, 11:17:35 AM
That, of course, assumes the meter is reading correctly.   I've always been taught - never assume anything.  Test and re test, the truth will be come apparant.
Stefan has suggested a crude diy clamp meter to keep the scope or dso away from the high voltage line by using a ferrite toroid windings. This will not give you an absolute current reading but it will give you a good insight of the current behavior and frequency. Like he said without empirical data we are just touching in the dark.
hartiberlin
Quote from: MrWolf on June 20, 2010, 10:28:08 AM
Found gold! Original full "On Light And Other High Frequency Phenomenon",
not the partial (censored?) stuff you usually find on the net.
http://www.electrotherapymuseum.com/TeslaArchive/Lectures.htm
http://www.electrotherapymuseum.com/TeslaArchive/OnLight/index.htm
Many thanks for finding this !
Especially the second one from page 50 on is very interesting,
as it lectures on the production of ONE WIRE systems
and also the hairpin circuits.
Maybe someone can put this in a PDF file,
it can be read easier ?
By the way, I watched yeasterday the youtube video series ( 10 movies) about the
Tesla Hairpin device and it is fascinating to see,
that you can light up bulbs under water and don´t get shocked,
when you touch the both connection wires and the water.
http://www.youtube.com/watch?v=UsS0BeVeIwM
and the next 9 parts..
Karl Palsness demostrating it, says, these are scalar waves powering
the bulbs, but I wonder, if it is not just high frequency RF currents
and standing waves ?
I think researching this and finding the exact differences to normal
RF currents and how to produce these strange currents is
vital also to the understanding of the Kapanadze and the Naudin Kapagen
circuits and replications.
I hope we can achive this here.
ALso great progress from all the experimentors here.
Many thanks.
hartiberlin
Quote from: broli on June 20, 2010, 12:07:39 PM
Boli,
many thanks for the drawing,
but just a normal 10 turn pickup coil without toroid and not wound around the line wire will
already show the waveforms picked up via magnetic induction.
Just bring it closer to the circuit until you see the waveforms on your scope,
but not to close, so will not kill your scope.
Regards, Stefan.
hartiberlin
You can do it just this way.
Sorry for the sloppy drawing, but I am in a hurry right now.
Regards, Stefan.
MrWolf
So far it seems only 1:1 replication is made by SR193, admin of russian next-energy forum. Here is the thread:
http://next-energy.ru/forum/index.php?topic=40.0
I have read around half of it and he seems real intelligent guy but for some reason he is very reluctant to give all the details, he wants everyone to think for themselves and only gives hints. In his video device is exactly like Kapanadze original: heating power transformers, low power HV sparkgap, very low internal power consumption, self running:
Video is here and I translated it as good as I could:
http://www.youtube.com/watch?v=BZUogv5YMXE
00:05 I shall now demonstrate my replication of Kapanadze machine.
00:20 I use central heating system for ground, because all pipes
are grounded.
00:35 Ground cable is TP5 twisted pair.
00:40 All wires are twisted together and connected to the pipe.
00:55 Ground wire goes into the center of device.
00:58 This is output transformer.
01:04 I will tell this right away, transformer has ferromagnetic core.
I tell this because otherwise many people will start again building
various resonant contours.
01:20 I wanted to use battery for startup, but sadly its dead.
01:27 Here are startup wires.
01:33 Power source.
01:36 Start.
01:40 Now we have 20V in startup wires.
01:54 With 20V I charge ~4700 microfarad capacitor.
01:59 Capacitor will charge and I will use it for startup.
02:04 Two buttons, right one for start, left on for stop.
02:10 I messed up so stop does not work.
02:13 Now I'll start the system.
02:25 We see fan that is cooling two high power transistors.
02:28 Here is our belowed spark gap.
02:35 I connected 150W bulb.
02:40 Cannot get more (yet).
02:47 Now we can disconnect power source.
02:59 I can short the wires to show that capacitor is now empty
and unused.
03:02 System still works.
03:05 Look at spark gap.
03:10 Switched off power source.
03:17 I can touch the ground wire. No shock. Despite wishes of some Internet users (sarcastic).
03:31 As I told you, device is not too complex.
03:34 This transistor is used for (Translator: signal?) generation.
03:37 Here is HV transformer.
03:42 HV transformer makes HV and SG ignites.
03:40 As you see SG is not powerful. SG does not need to be high power.
03:56 Spark gap just stimulates the process that takes place in
ferromagnetic core.
04:04 After that all is connected, thereunder is transformer for 220V.
04:10 Transformer is powered by output coil.
04:15 Output coil also powers the bulb. (Translator: I think he means thru 220V transformer, not directly)
04:20 Here we see 150W of power.
04:25 Paper is burning.
04:29 From output transformer power goes to 220V transformer below and closed loop is formed.
04:36 We can say this is free energy.
04:44 Cannot stop it right now, will short the wires, otherwise
it will all burn. (Translator: I think he means because of
smoldering bulb box)
04:44 I'm stopping the system.
05:00 Wires were not shorted.
05:17 I'm shorting and discharging capacitor.
05:22 It's all discharged and device is sopped for good.
05:26 As you see bulb heats strongly.
05:31 Let's unshort the wires.
05:40 Trying to start, does not start.
05:46 To start again we must use power source.
05:51 Ok, it's all connected again.
05:55 Power on.
06:00 Voltage is 12V.
06:04 Source is rated at only 1A.
06:09 In theory you can use any small battery to start it.
06:16 For start you must only charge the 4700 microfarad capacitor.
06:28 Start.
06:46 Will take off startup wires.
06:52 OK, it burns very nicely.
06:59 That's all, will fight the flames now.
07:00 Bye.
